Hi!
I'm trying to apply the code from
https://blog.codecentric.de/en/2013/03/java-based-machine-learning-by-classification/ on my process which tests the classification of Arabic texts. I made the training and testing in two separate processes. Now I only need the testing process.
Here's the XML
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="414" width="762">
<operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve" width="90" x="112" y="75">
<parameter key="repository_entry" value="wordlistAr"/>
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="246" y="30">
<list key="text_directories">
<parameter key="أخبار" value="C:\Users\WINDOWS 7\Desktop\rapid2\AraTest\New folder"/>
</list>
<parameter key="file_pattern" value="*"/>
<parameter key="extract_text_only" value="true"/>
<parameter key="use_file_extension_as_type" value="true"/>
<parameter key="content_type" value="txt"/>
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="TF-IDF"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="false"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
<operator activated="true" class="text:filter_stopwords_arabic" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (Arabic)" width="90" x="45" y="165"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.3.002" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="45" y="255">
<parameter key="max_length" value="1"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (Arabic)" to_port="document"/>
<connect from_op="Filter Stopwords (Arabic)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve (2)" width="90" x="447" y="30">
<parameter key="repository_entry" value="modelAr"/>
<operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="514" y="165">
<parameter key="create_view" value="false"/>
<connect from_op="Retrieve" from_port="output" to_op="Process Documents from Files" to_port="word list"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model" to_port="model"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
and here is the java code
// Path to process-definition
final String processPath =
"C:/Users/WINDOWS 7/.RapidMiner5/repositories/NewLocalRepository/TestNews.rmp";
// Init RapidMiner
RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE);
RapidMiner.init();
try
// Load process
final com.rapidminer.Process process =
new com.rapidminer.Process(new File(processPath));
// Load learned model
final RepositoryLocation locWordList = new RepositoryLocation(
"//NewLocalRepository/modelAr.model");
final IOObject wordlist = ((IOObjectEntry)
locWordList.locateEntry()).retrieveData(null);
// Load Wordlist
final RepositoryLocation locModel = new RepositoryLocation(
"//NewLocalRepository/wordlistAr.wordlist");
final IOObject model = ((IOObjectEntry)
locModel.locateEntry()).retrieveData(null);
final IOContainer ioInput = new IOContainer(new IOObject[] { wordlist, model });
process.run(ioInput);
final long start = System.currentTimeMillis();
final IOContainer ioResult = process.run();
final long end = System.currentTimeMillis();
System.out.println("T:" + (end - start));
// Print some results
final SimpleExampleSet ses = ioResult.get(SimpleExampleSet.class);
for (int i = 0; i < Math.min(5, ses.size()); i++) {
final Example example = ses.getExample(i);
final Attributes attributes = example.getAttributes();
final String id = example.getValueAsString(attributes.getId());
final String prediction = example.getValueAsString(
attributes.getPredictedLabel());
System.out.println("Path: " + id + ":\tPrediction:" + prediction);
catch(Exception e)
{e.printStackTrace();}
it says the problem is with this line
Thank you in advance
