1. What is the best distance measure in this case?
2. Do I need to transform any attribute?
3. Do I need to normalize any attribute?
4. What is the best way to set up the model?
Hi Martin,
What would be the approach if there are more categorical variables, especially of nominal type?
In khannadh's list of attributes, if there are more nominals like - 5. Location of the customer 6. Preferred marketing material.
What is the recommended approach for clustering in RM?
I use Gower distance for mixed datatypes in R.
Thanks!
