"One class Svm Error"
udaykumar
Lib svm caused error : one-class SVM probability output not supported yet.
The process is as follows
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="5.3.015" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30">
<parameter key="csv_file" value="/home/user/Desktop/sys_logSlot 3_new_oneclass.csv"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="UTF-8"/>
<parameter key="0" value="date.false.polynominal.attribute"/>
<parameter key="1" value="os.false.binominal.attribute"/>
<parameter key="2" value="type.false.binominal.attribute"/>
<parameter key="3" value="msg.true.integer.attribute"/>
<parameter key="4" value="Slot.false.integer.attribute"/>
<parameter key="5" value="rea.true.polynominal.attribute"/>
<parameter key="6" value="date1.false.polynominal.attribute"/>
<parameter key="7" value="os1.false.binominal.attribute"/>
<parameter key="8" value="type1.false.binominal.attribute"/>
<parameter key="9" value="msg1.true.integer.attribute"/>
<parameter key="10" value="Slot1.false.integer.attribute"/>
<parameter key="11" value="rea1.true.polynominal.attribute"/>
<parameter key="12" value="date2.false.polynominal.attribute"/>
<parameter key="13" value="os2.false.binominal.attribute"/>
<parameter key="14" value="type2.false.binominal.attribute"/>
<parameter key="15" value="msg2.true.integer.attribute"/>
<parameter key="16" value="Slot2.false.integer.attribute"/>
<parameter key="17" value="rea2.true.polynominal.attribute"/>
<parameter key="18" value="date3.false.polynominal.attribute"/>
<parameter key="19" value="os3.false.binominal.attribute"/>
<parameter key="20" value="type3.false.binominal.attribute"/>
<parameter key="21" value="msg3.true.integer.attribute"/>
<parameter key="22" value="Slot3.false.integer.attribute"/>
<parameter key="23" value="rea3.true.polynominal.attribute"/>
<parameter key="24" value="date4.false.polynominal.attribute"/>
<parameter key="25" value="os4.false.binominal.attribute"/>
<parameter key="26" value="type4.false.binominal.attribute"/>
<parameter key="27" value="msg4.true.integer.attribute"/>
<parameter key="28" value="Slot4.false.integer.attribute"/>
<parameter key="29" value="rea4.true.polynominal.attribute"/>
<parameter key="30" value="Error.true.binominal.label"/>
<parameter key="31" value="P(Error).true.attribute_value.prediction"/>
</list>
<operator activated="true" class="nominal_to_numerical" compatibility="5.3.015" expanded="true" height="94" name="Nominal to Numerical" width="90" x="45" y="120">
<list key="comparison_groups"/>
<operator activated="true" class="set_role" compatibility="5.3.015" expanded="true" height="76" name="Set Role" width="90" x="179" y="210">
<parameter key="attribute_name" value="Error"/>
<operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="112" name="Validation (2)" width="90" x="246" y="30">
<description>A cross-validation evaluating a linear regression model.</description>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="5.3.015" expanded="true" height="76" name="SVM" width="90" x="45" y="30">
<parameter key="svm_type" value="one-class"/>
<parameter key="kernel_type" value="poly"/>
<parameter key="degree" value="5"/>
<list key="class_weights"/>
<parameter key="calculate_confidences" value="true"/>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
<operator activated="true" class="write_csv" compatibility="5.3.015" expanded="true" height="76" name="Write CSV" width="90" x="45" y="165">
<parameter key="csv_file" value="/home/user/Desktop/feb_18/output_model_csv.csv"/>
<operator activated="true" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="112" y="255">
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Write CSV" to_port="input"/>
<connect from_op="Write CSV" from_port="through" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/>
<connect from_op="Nominal to Numerical" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Validation (2)" to_port="training"/>
<connect from_op="Validation (2)" from_port="model" to_port="result 1"/>
<connect from_op="Validation (2)" from_port="averagable 1" to_port="result 2"/>
</process>
</process>
Please help to solve this issue
1) tell me how to use one class svm for poynomial and binomial attributes
Thank you
Errors
SVMs
MartinLiebig
a SVM is simply not supporting nominal values by design. You can use Nominal to Numiercial to change the type. Then you would most likely create a dummy coding.
cheers,
martin
udaykumar
I have used nominal to numerical operator but after that also it showing same errror.
My data looks like this
a1 a2 a3 a4 a5
date polynomial binomial error(one class label) prediction
i am predicting error from this but it is showing
one class svm not supported yet
so
please help me regarding this.
I have already sent process xml file
