[SOLVED] Rapidminer 5.3 on Linux
spok2
Dear all,
many thanks in advance for a hint what might be wrong ...
I use a text mining process on Windows, consisting of
- Process documents from files
-- Tokenize
-- Filter Stopwords
-- Stem (Porter)
-- Filter Tokens by Length
-- Transform Cases
with no problems.
Now I tried to copy the process to Ubuntu 14.04
- either by copying the *.rpm file
- or by newly creating the process on ubuntu
To my opinion both processes are identical; both tell me: "No problems found"
Starting the process on Windows I get results after about 2 minutes (Wordlist and Example Set)
Starting the process on Ubuntu I get an emty result after 0 seconds (Wordlist as well as Example set are both empty); process stops without errors.
What might go wrong?
Linux + variants
Marco_Boeck
my bet would be some encoding issue. Check your process XML for weird symbols.
Marco
spok2
Marco,
thanks, but this is not the problem.
What I did (System: Ubuntu 14.04 with Oracle Java 1.8.0_31):
- completely deleted rapidminer, including .RapidMiner5 in $HOME
- downloaded rapidminer 5.3.13 from Sourceforge
- unzip below my local homedir
- set all dirs to 755, all files to 644
- copied 5 arbitrary english articles from the web and put them in a directory
- copied RapidMinerGUI from scripts to installation dir
- started rapidminer
- made update to 5.3.15
- installed extensions
- created a new process, consisting of the elements I already mentioned (xml see below)
- get no errors, as well as no results after running the process, ready within 0s
Same process runs on Windows 7 without any problem
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="30">
<list key="text_directories">
<parameter key="Files" value="/home/XXX/Data/ParticleFoam/test.null"/>
</list>
<parameter key="prune_method" value="percentual"/>
<parameter key="prune_above_percent" value="95.0"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="45" y="120"/>
<operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="45" y="210"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="45" y="300">
<parameter key="min_chars" value="3"/>
<parameter key="max_chars" value="50"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="246" y="30"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Process Documents from Files" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents from Files" from_port="word list" to_port="result 2"/>
</process>
</process>
Marco_Boeck
there is one difference which might be responsible: On Linux, you're using your local Java installation, i.e. Java 8 in your case. On Windows, a JRE is shipped with RapidMiner, so you're using a Java 7 version there. You might want to try again on Linux with Java 7.
Marco
spok2
Marco,
thanks, thatś it ...
I removed Oracle Java8, installed Oracle Java7 and all is fine.
Best regards
Wolfgang
