XML
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="5.3.015" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="C:\Users\Heiko\Documents\Forschung\DBpediaDebugging\redirects\training_features.csv"/> <parameter key="column_separators" value="	"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Original.true.polynominal.id"/> <parameter key="1" value="Replaced.true.polynominal.batch"/> <parameter key="2" value="Correct.true.binominal.label"/> <parameter key="3" value="Plausible.true.integer.attribute"/> <parameter key="4" value="Distribution.true.real.attribute"/> <parameter key="5" value="Levenstein.true.integer.attribute"/> <parameter key="6" value="Levenstein (relative).true.real.attribute"/> <parameter key="7" value="Jaccard.true.real.attribute"/> <parameter key="8" value="Jaro.true.real.attribute"/> <parameter key="9" value="JaroWinkler.true.real.attribute"/> <parameter key="10" value="Prefix.true.real.attribute"/> <parameter key="11" value="Prefix2.true.real.attribute"/> <parameter key="12" value="Substring1.true.real.attribute"/> <parameter key="13" value="Substring2.true.real.attribute"/> <parameter key="14" value="Redirects.true.integer.attribute"/> <parameter key="15" value="Disambiguations.true.integer.attribute"/> </list> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.3.015" expanded="true" height="94" name="Optimize Parameters (2)" width="90" x="246" y="30"> <list key="parameters"> <parameter key="SVM (4).gamma" value="[0.0000001;1000000;13;logarithmic]"/> <parameter key="SVM (4).C" value="[0.0000001;1000000;13;logarithmic]"/> </list> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="112" name="Validation (3)" width="90" x="246" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.3.015" expanded="true" height="76" name="SVM (4)" width="90" x="90" y="30"> <parameter key="gamma" value="1.0000000000000003E-4"/> <parameter key="C" value="1000000.0"/> <list key="class_weights"> <parameter key="0" value="20.0"/> <parameter key="1" value="1.0"/> </list> </operator> <connect from_port="training" to_op="SVM (4)" to_port="training set"/> <connect from_op="SVM (4)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (5)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance (5)" width="90" x="179" y="30"> <parameter key="f_measure" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (5)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (5)" to_port="unlabelled data"/> <connect from_op="Apply Model (5)" from_port="labelled data" to_op="Performance (5)" to_port="labelled data"/> <connect from_op="Performance (5)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Validation (3)" to_port="training"/> <connect from_op="Validation (3)" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Read CSV" from_port="output" to_op="Optimize Parameters (2)" to_port="input 1"/> <connect from_op="Optimize Parameters (2)" from_port="parameter" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
double d1 = 1.0;double d2 = 1.0/0.0;System.out.println(d1>d2);System.out.println(d2>d1);
