ı got the same error:\ Help please...
hey, ı solved this error now and ı wanted to share it , thanks to https://www.infocaptor.com/dashboard/jdbc-with-sqlserver-connection-refused-connect...
if you would get the same error , ı guess you will solve this error when visited the link...
hello @Mustafa_AVDAN - welcome to the community. Looks like a port / network issue. You may want to double check all of your settings and make sure there are no ports being blocked, etc...
Scott
[EDIT: sorry @Mustafa_AVDAN - your followup post was caught in the spam filter for some weird reason. Apologies. Glad you found the solution!]
