<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <parameter key="logfile" value="C:\Documents and Settings\charper\My Documents\ALiNBUS\googlepagesstep3log"/> <parameter key="resultfile" value="C:\Documents and Settings\charper\My Documents\ALiNBUS\googlepagesstep3result"/> <process expanded="true"> <operator activated="true" class="loop_examples" compatibility="6.2.000" expanded="true" height="94" name="Loop Examples" width="90" x="313" y="255"> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="6.2.000" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30"> <parameter key="macro" value="href"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="site"/> <parameter key="example_index" value="%{example}"/> <list key="additional_macros"/> </operator> <operator activated="true" class="handle_exception" compatibility="6.2.000" expanded="true" height="94" name="Handle Exception" width="90" x="246" y="30"> <parameter key="exception_macro" value="exceptionmsg"/> <process expanded="true"> <operator activated="false" class="text:extract_token_number" compatibility="6.1.000" expanded="true" height="60" name="Extract Token Number" width="90" x="45" y="435"> <parameter key="condition" value="matches"/> <parameter key="regular_expression" value="LIBRAR"/> </operator> <operator activated="false" class="text:extract_token_number" compatibility="6.1.000" expanded="true" height="60" name="Extract Token Number (2)" width="90" x="179" y="480"> <parameter key="metadata_key" value="LIBRARnumber"/> <parameter key="condition" value="matches"/> <parameter key="regular_expression" value="LIBRAR"/> <parameter key="invert_condition" value="true"/> </operator> <operator activated="true" class="web:get_webpage" compatibility="5.3.002" expanded="true" height="60" name="Get Page" width="90" x="45" y="75"> <parameter key="url" value="%{href}"/> <parameter key="random_user_agent" value="true"/> <list key="query_parameters"/> <list key="request_properties"/> </operator> <operator activated="true" class="web:extract_html_text_content" compatibility="5.3.002" expanded="true" height="60" name="Extract Content" width="90" x="179" y="75"/> <operator activated="false" class="text:tokenize" compatibility="6.1.000" expanded="true" height="60" name="Tokenize" width="90" x="179" y="165"/> <operator activated="false" class="text:stem_snowball" compatibility="6.1.000" expanded="true" height="60" name="Stem (Snowball)" width="90" x="179" y="255"> <parameter key="language" value="Russian"/> </operator> <operator activated="false" class="text:documents_to_data" compatibility="6.1.000" expanded="true" height="60" name="Documents to Data (2)" width="90" x="112" y="345"> <parameter key="text_attribute" value="contents"/> <parameter key="label_attribute" value="Href"/> </operator> <connect from_port="in 1" to_port="out 1"/> <connect from_op="Get Page" from_port="output" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_port="out 2"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> <process expanded="true"> <connect from_port="in 1" to_port="out 1"/> <connect from_port="in 2" to_port="out 2"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Handle Exception" to_port="in 1"/> <connect from_op="Handle Exception" from_port="out 1" to_port="example set"/> <connect from_op="Handle Exception" from_port="out 2" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
