<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="75"> <list key="attribute_values"> <parameter key="text" value=""find needle in haystack""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="112" y="300"> <list key="attribute_values"> <parameter key="text" value=""nothing to see here""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="6.1.000" expanded="true" height="94" name="Append" width="90" x="179" y="165"/> <operator activated="true" class="generate_attributes" compatibility="6.1.000" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="210"> <list key="function_descriptions"> <parameter key="needleBinominal" value="matches(text,".*needle.*")"/> </list> </operator> <operator activated="true" class="text:generate_extract" compatibility="6.1.000" expanded="true" height="60" name="Generate Extract" width="90" x="447" y="210"> <parameter key="source_attribute" value="text"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="needleNominal" value=".*(needle).*"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
hi
how to write expression for get the specific word list.
how to write expression in generate attribute operator for getting specific word list
Hi @rajbanokhan
I don't understand exactily what you want but :
I propose to you 2 elements of response :
1. first this process
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="75"> <list key="attribute_values"> <parameter key="text" value=""test wordA""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="112" y="187"> <list key="attribute_values"> <parameter key="text" value=""test wordB""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification (3)" width="90" x="112" y="289"> <list key="attribute_values"> <parameter key="text" value=""test wordC""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification (4)" width="90" x="112" y="391"> <list key="attribute_values"> <parameter key="text" value=""test wordB hello wordA good morning wordC""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="8.0.001" expanded="true" height="145" name="Append" width="90" x="380" y="187"/> <operator activated="true" class="nominal_to_text" compatibility="8.0.001" expanded="true" height="82" name="Nominal to Text" width="90" x="514" y="187"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="82" name="Generate Attributes" width="90" x="648" y="187"> <list key="function_descriptions"> <parameter key="needleBinominal" value="contains(text,"wordA")&&contains(text,"wordB")&&contains(text,"wordC")"/> </list> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="782" y="187"> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"> <parameter key="expression" value="(word1\b)(word2\b)(word3\b)"/> </operator> <operator activated="true" class="multiply" compatibility="8.0.001" expanded="true" height="124" name="Multiply" width="90" x="246" y="187"/> <operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (4)" width="90" x="514" y="442"> <parameter key="string" value="wordC"/> </operator> <operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (3)" width="90" x="514" y="289"> <parameter key="string" value="wordA"/> </operator> <operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="514" y="85"> <parameter key="string" value="wordB"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Tokens (3)" to_port="document"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Multiply" from_port="output 3" to_op="Filter Tokens (4)" to_port="document"/> <connect from_op="Filter Tokens (4)" from_port="document" to_port="document 3"/> <connect from_op="Filter Tokens (3)" from_port="document" to_port="document 2"/> <connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> <portSpacing port="sink_document 3" spacing="0"/> <portSpacing port="sink_document 4" spacing="0"/> </process> </operator> <operator activated="false" class="text:generate_extract" compatibility="7.5.000" expanded="true" height="68" name="Generate Extract" width="90" x="514" y="391"> <parameter key="source_attribute" value="text"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="word1_word2_word3_Nominal" value="(?=.*wordA)(?=.*wordB)(?=.*wordC)"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Append" from_port="merged set" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
2. this second process
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="75"> <list key="attribute_values"> <parameter key="text" value=""test wordA""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="112" y="187"> <list key="attribute_values"> <parameter key="text" value=""test wordB""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification (3)" width="90" x="112" y="289"> <list key="attribute_values"> <parameter key="text" value=""test wordC""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="6.4.000" expanded="true" height="68" name="Generate Data by User Specification (4)" width="90" x="112" y="391"> <list key="attribute_values"> <parameter key="text" value=""test wordB hello wordA good morning wordC""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="8.0.001" expanded="true" height="145" name="Append" width="90" x="380" y="187"/> <operator activated="true" class="nominal_to_text" compatibility="8.0.001" expanded="true" height="82" name="Nominal to Text" width="90" x="514" y="187"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="82" name="Generate Attributes" width="90" x="648" y="187"> <list key="function_descriptions"> <parameter key="needleBinominal" value="contains(text,"wordA")&&contains(text,"wordB")&&contains(text,"wordC")"/> </list> </operator> <operator activated="false" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="782" y="442"> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"> <parameter key="expression" value="(word1\b)(word2\b)(word3\b)"/> </operator> <operator activated="true" class="multiply" compatibility="8.0.001" expanded="true" height="124" name="Multiply" width="90" x="246" y="187"/> <operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (4)" width="90" x="514" y="442"> <parameter key="string" value="wordC"/> </operator> <operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (3)" width="90" x="514" y="289"> <parameter key="string" value="wordA"/> </operator> <operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="514" y="85"> <parameter key="string" value="wordB"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Tokens (3)" to_port="document"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Multiply" from_port="output 3" to_op="Filter Tokens (4)" to_port="document"/> <connect from_op="Filter Tokens (4)" from_port="document" to_port="document 3"/> <connect from_op="Filter Tokens (3)" from_port="document" to_port="document 2"/> <connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> <portSpacing port="sink_document 3" spacing="0"/> <portSpacing port="sink_document 4" spacing="0"/> </process> </operator> <operator activated="true" class="text:generate_extract" compatibility="7.5.000" expanded="true" height="68" name="Generate Extract" width="90" x="782" y="187"> <parameter key="source_attribute" value="text"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="word1_word2_word3_Nominal" value="(?=.*wordA)(?=.*wordB)(?=.*wordC)"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Append" from_port="merged set" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
fot this last process , i don't undestand why the colums where there are all the wanted words, thre are nothing displayed.
Regards;
Lionel
i want to search specific word from text. for example we have a paragraph and i want to search a word from it
so i use "The Generate Attributes operator" and how i write "Use the matches function and a suitable regular expression".
