<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.001-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.001-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.1.001-SNAPSHOT" expanded="true" height="60" name="Retrieve Sonar" width="90" x="179" y="120"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="linear_regression" compatibility="6.1.001-SNAPSHOT" expanded="true" height="94" name="Linear Regression" width="90" x="380" y="120"/> <operator activated="true" class="weights_to_data" compatibility="6.1.001-SNAPSHOT" expanded="true" height="60" name="Weights to Data" width="90" x="514" y="165"/> <connect from_op="Retrieve Sonar" from_port="output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/> <connect from_op="Weights to Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.001-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.001-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.1.001-SNAPSHOT" expanded="true" height="60" name="Generate Data" width="90" x="45" y="210"/> <operator activated="true" class="multiply" compatibility="6.1.001-SNAPSHOT" expanded="true" height="94" name="Multiply" width="90" x="246" y="165"/> <operator activated="true" class="loop_attributes" compatibility="6.1.001-SNAPSHOT" expanded="true" height="76" name="Loop Attributes" width="90" x="380" y="345"> <process expanded="true"> <operator activated="true" class="set_data" compatibility="6.1.001-SNAPSHOT" expanded="true" height="76" name="Set Data" width="90" x="179" y="120"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="value" value="0"/> <list key="additional_values"/> </operator> <connect from_port="example set" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="filter_examples" compatibility="6.1.001-SNAPSHOT" expanded="true" height="94" name="Filter Examples" width="90" x="514" y="345"> <list key="filters_list"> <parameter key="filters_entry_key" value="att1.eq.0"/> </list> </operator> <operator activated="true" class="linear_regression" compatibility="6.1.001-SNAPSHOT" expanded="true" height="94" name="Linear Regression" width="90" x="447" y="120"/> <operator activated="true" class="apply_model" compatibility="6.1.001-SNAPSHOT" expanded="true" height="76" name="Apply Model" width="90" x="581" y="210"> <list key="application_parameters"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Linear Regression" to_port="training set"/> <connect from_op="Multiply" from_port="output 2" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Linear Regression" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="180"/> <portSpacing port="sink_result 2" spacing="18"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
