I want to calculate the average value for each attributes in Iris Data Set, so I use the Operator "Loop Attributes" and "Aggregate". But I get the Error Message: "The given example set does not contain an attribute a2."
just like in the picture
Why???
My Process is
<process version="6.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="30">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="loop_attributes" compatibility="6.1.000" expanded="true" height="76" name="Loop Attributes" width="90" x="313" y="30">
<parameter key="value_type" value="real"/>
<operator activated="true" class="aggregate" compatibility="6.1.000" expanded="true" height="76" name="Aggregate" width="90" x="112" y="30">
<parameter key="%{loop_attribute}" value="average"/>
</list>
<connect from_port="example set" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_port="example set"/>
<portSpacing port="sink_example set" spacing="0"/>
</process>
<connect from_op="Retrieve Iris" from_port="output" to_op="Loop Attributes" to_port="example set"/>
<connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/>
</process>
</process>
Best Reguards!
blatoo
