<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.1.001-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.1.001-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_nominal_data" compatibility="6.1.001-SNAPSHOT" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="75"/> <operator activated="true" class="generate_id" compatibility="6.1.001-SNAPSHOT" expanded="true" height="76" name="Generate ID" width="90" x="179" y="75"/> <operator activated="true" class="multiply" compatibility="6.1.001-SNAPSHOT" expanded="true" height="94" name="Multiply" width="90" x="313" y="75"/> <operator activated="true" class="nominal_to_numerical" compatibility="6.1.001-SNAPSHOT" expanded="true" height="94" name="Nominal to Numerical" width="90" x="514" y="30"> <list key="comparison_groups"/> </operator> <operator activated="true" class="k_means" compatibility="6.1.001-SNAPSHOT" expanded="true" height="76" name="Clustering" width="90" x="647" y="30"/> <operator activated="true" class="select_attributes" compatibility="6.1.001-SNAPSHOT" expanded="true" height="76" name="Select Attributes" width="90" x="781" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="cluster|id|label"/> </operator> <operator activated="true" class="join" compatibility="6.1.001-SNAPSHOT" expanded="true" height="76" name="Join" width="90" x="916" y="75"> <list key="key_attributes"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Join" to_port="right"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="clustered set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
I am interested in that topic, too!
did you solve how to apply NB with clustering? can you show me how?
