<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Set B" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="filter_example_range" compatibility="6.0.008" expanded="true" height="76" name="Filter Example Range" width="90" x="179" y="120"> <parameter key="first_example" value="5"/> <parameter key="last_example" value="8"/> </operator> <operator activated="true" class="extract_macro" compatibility="6.0.008" expanded="true" height="60" name="Size B" width="90" x="313" y="120"> <parameter key="macro" value="size_b"/> <list key="additional_macros"/> </operator> <operator activated="true" class="loop" compatibility="6.0.008" expanded="true" height="76" name="SET A" width="90" x="45" y="30"> <parameter key="iterations" value="10"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Retrieve Golf" width="90" x="112" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.0.008" expanded="true" height="76" name="Append" width="90" x="179" y="30"/> <operator activated="true" class="extract_macro" compatibility="6.0.008" expanded="true" height="60" name="Size A" width="90" x="313" y="30"> <parameter key="macro" value="size_a"/> <list key="additional_macros"/> </operator> <operator activated="true" class="subprocess" compatibility="6.0.008" expanded="true" height="94" name="Find Match" width="90" x="514" y="75"> <process expanded="true"> <operator activated="true" class="loop" compatibility="6.0.008" expanded="true" height="94" name="Loop Content" width="90" x="313" y="30"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="%{size_a}"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="6.0.008" expanded="true" height="76" name="Generate Macro" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="end_index" value="str(%{iteration} + %{size_b} - 1)"/> </list> </operator> <operator activated="true" class="filter_example_range" compatibility="6.0.008" expanded="true" height="76" name="Filter Example Range (2)" width="90" x="447" y="30"> <parameter key="first_example" value="%{iteration}"/> <parameter key="last_example" value="%{end_index}"/> </operator> <operator activated="true" class="subprocess" compatibility="6.0.008" expanded="true" height="94" name="Compare" width="90" x="581" y="75"> <process expanded="true"> <operator activated="true" class="loop" compatibility="6.0.008" expanded="true" height="94" name="Loop" width="90" x="179" y="30"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_name" value="pattern_row"/> <parameter key="iterations" value="%{size_b}"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="6.0.008" expanded="true" height="76" name="Filter Example Range (3)" width="90" x="112" y="30"> <parameter key="first_example" value="%{pattern_row}"/> <parameter key="last_example" value="%{pattern_row}"/> </operator> <operator activated="true" class="filter_example_range" compatibility="6.0.008" expanded="true" height="76" name="Filter Example Range (4)" width="90" x="112" y="120"> <parameter key="first_example" value="%{pattern_row}"/> <parameter key="last_example" value="%{pattern_row}"/> </operator> <operator activated="true" class="append" compatibility="6.0.008" expanded="true" height="94" name="Append (2)" width="90" x="246" y="75"/> <operator activated="true" class="remove_duplicates" compatibility="6.0.008" expanded="true" height="76" name="Remove Duplicates" width="90" x="380" y="75"> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_port="input 1" to_op="Filter Example Range (3)" to_port="example set input"/> <connect from_port="input 2" to_op="Filter Example Range (4)" to_port="example set input"/> <connect from_op="Filter Example Range (3)" from_port="example set output" to_op="Append (2)" to_port="example set 1"/> <connect from_op="Filter Example Range (4)" from_port="example set output" to_op="Append (2)" to_port="example set 2"/> <connect from_op="Append (2)" from_port="merged set" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.0.008" expanded="true" height="76" name="Append (3)" width="90" x="313" y="30"/> <operator activated="true" class="branch" compatibility="6.0.008" expanded="true" height="76" name="Branch" width="90" x="514" y="30"> <parameter key="condition_type" value="max_examples"/> <parameter key="condition_value" value="%{size_b}"/> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="6.0.008" expanded="true" height="60" name="Start Match Table" width="90" x="179" y="30"> <list key="attribute_values"> <parameter key="match_in_line" value="%{iteration}"/> </list> <list key="set_additional_roles"/> </operator> <connect from_op="Start Match Table" from_port="output" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Loop" to_port="input 1"/> <connect from_port="in 2" to_op="Loop" to_port="input 2"/> <connect from_op="Loop" from_port="output 1" to_op="Append (3)" to_port="example set 1"/> <connect from_op="Append (3)" from_port="merged set" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/> <connect from_port="input 2" to_op="Compare" to_port="in 2"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Filter Example Range (2)" to_port="example set input"/> <connect from_op="Filter Example Range (2)" from_port="example set output" to_op="Compare" to_port="in 1"/> <connect from_op="Compare" from_port="out 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.0.008" expanded="true" height="76" name="Collect Matches" width="90" x="447" y="30"/> <connect from_port="in 1" to_op="Loop Content" to_port="input 1"/> <connect from_port="in 2" to_op="Loop Content" to_port="input 2"/> <connect from_op="Loop Content" from_port="output 1" to_op="Collect Matches" to_port="example set 1"/> <connect from_op="Collect Matches" from_port="merged set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Set B" from_port="output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Size B" to_port="example set"/> <connect from_op="Size B" from_port="example set" to_op="Find Match" to_port="in 2"/> <connect from_op="SET A" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Size A" to_port="example set"/> <connect from_op="Size A" from_port="example set" to_op="Find Match" to_port="in 1"/> <connect from_op="Find Match" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
