<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.009" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="set_macro" compatibility="6.0.009" expanded="true" height="76" name="Set Macro" width="90" x="179" y="30"> <parameter key="macro" value="date"/> <parameter key="value" value="22.07.2014"/> </operator> <operator activated="true" class="generate_macro" compatibility="6.0.009" expanded="true" height="76" name="Generate Macro" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="date" value="date_add(date_parse_custom("%{date}", "dd.MM.yyyy", "en"), 1, DATE_UNIT_DAY)"/> </list> </operator> <operator activated="true" class="print_to_console" compatibility="6.0.009" expanded="true" height="76" name="Print to Console" width="90" x="447" y="30"> <parameter key="log_value" value="%{date}"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Print to Console" to_port="through 1"/> <connect from_op="Print to Console" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
