Dear community,
I am struggeling to load a RapidMiner process containing an "Execute Script (R)" operator in my Java project. I have set up R in RapidMiner correctly and when I start the process directly from the RapidMiner GUI, it works. However, when I try to load the process in my Java project, I receive the following notification:
Jul 16, 2014 10:21:02 AM org.rosuda.JRI.Rengine <clinit>
INFO: Creating Connection to R...
Jul 16, 2014 10:21:02 AM org.rosuda.JRI.Rengine isJriLoaded
WARNING: Access on uninitialized Rengine!
INFO: Engine ID: class org.rosuda.JRI.Rengine ClassLoader:PluginClassLoader ([file:/C:/Users/Uli/.RapidMiner5/managed/rmx_r-5.3.0.jar])
Jul 16, 2014 10:21:02 AM com.rapidminer.tools.r.JRIRSession initializeEngine
SEVERE: Could not initialize R via JRI. Reason: Library wasn't loaded.
Exception in thread "main" com.rapidminer.operator.OperatorException: Could not initiate session with native R. Try using server. Reason: Could not initialize R via JRI. Reason: Library wasn't loaded.
at com.rapidminer.tools.r.RSessionManager.acquireSession(RSessionManager.java:239)
at com.rapidminer.tools.r.RSessionManager.acquireSession(RSessionManager.java:196)
at com.rapidminer.operator.r.RScriptOperator.doWork(RScriptOperator.java:185)
at com.rapidminer.operator.Operator.execute(Operator.java:867)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:375)
at com.rapidminer.Process.run(Process.java:949)
at com.rapidminer.Process.run(Process.java:873)
at com.rapidminer.Process.run(Process.java:832)
at com.rapidminer.Process.run(Process.java:827)
at com.rapidminer.Process.run(Process.java:817)
at QualityAssessmentOfDerivedVariables.<init>(QualityAssessmentOfDerivedVariables.java:28)
at ExecuteRapidMinerProcess.main(ExecuteRapidMinerProcess.java:22)
Caused by: org.rosuda.REngine.REngineException: Could not initialize R via JRI. Reason: Library wasn't loaded.
at com.rapidminer.tools.r.JRIRSession.initializeEngine(JRIRSession.java:324)
at com.rapidminer.tools.r.JRIRSession.<init>(JRIRSession.java:78)
at com.rapidminer.tools.r.RSessionManager.acquireSession(RSessionManager.java:235)
... 14 more
Caused by: org.rosuda.REngine.REngineException: Library wasn't loaded.
at org.rosuda.JRI.JRIEngine.<init>(JRIEngine.java:221)
at com.rapidminer.tools.r.JRIRSession.initializeEngine(JRIRSession.java:320)
... 16 more
The message "Could not initialize R via JRI. Reason: Library wasn't loaded" lets me assume that I have to set the path to the RJava library manually. Is this true? If so, how do I do this? I am running Win8.1 with RapidMiner 5.3.013.
Thank you + kind regards,
Uli
