"RapidMinerGUI java error"
I have just installed the Community Edition of RM Server on Ubuntu 14.04. I am getting the below error when trying to run RM from the cmd line. When I double click the RapidMinerGUI icon, nothing happens. Help is appreciated. Thanks.
peter@ubuntu:~/rapidminer/scripts$ ./RapidMinerGUI
Number of cores: 1
Number of GC Threads: 0
No maximum Java memory defined, using 1024 Mb...
Starting RapidMiner from '/home/peter/rapidminer', using classes from '/home/peter/rapidminer/lib/rapidminer.jar'...
Java version: 17
Starting with G1 garbage collector
Starting in single-core mode
Jul 14, 2014 2:24:09 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is '/home/peter/rapidminer'.
Jul 14, 2014 2:24:09 PM com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform ANY
Jul 14, 2014 2:24:09 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: Found left-behind lock file from last startup at /home/peter/.RapidMiner5/safeMode.lock.
Jul 14, 2014 2:24:09 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Jul 14, 2014 2:24:09 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Exception in thread "main" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.rapid_i.Launcher.main(Launcher.java:367)
Caused by: java.awt.HeadlessException
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:207)
at java.awt.Window.<init>(Window.java:535)
at java.awt.Frame.<init>(Frame.java:420)
at java.awt.Frame.<init>(Frame.java:385)
at javax.swing.SwingUtilities$SharedOwnerFrame.<init>(SwingUtilities.java:1756)
at javax.swing.SwingUtilities.getSharedOwnerFrame(SwingUtilities.java:1831)
at javax.swing.JDialog.<init>(JDialog.java:270)
at com.rapidminer.gui.tools.dialogs.ButtonDialog.<init>(ButtonDialog.java:125)
at com.rapidminer.gui.tools.dialogs.ConfirmDialog.<init>(ConfirmDialog.java:72)
at com.rapidminer.gui.safemode.SafeModeDialog.<init>(SafeModeDialog.java:44)
at com.rapidminer.gui.safemode.SafeModeDialog.showSafeModeDialog(SafeModeDialog.java:82)
at com.rapidminer.gui.safemode.SafeMode.askForSafeMode(SafeMode.java:87)
at com.rapidminer.gui.safemode.SafeMode.launchStarts(SafeMode.java:56)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:539)
... 5 more
