Hallo,
I am trying to do a simple model selection using cross validation in Rapidminer.
The goal is to evaluate various classification methods using
the same folds of cross validation for each method and select the one with the best averaged performance over the folds. This should be done within one process automatically.
Below is the process I've created to accomplish this goal.
The potential problem I see with this approach is the fact that the X-Validation operator is placed
within the Loop operator. I am not sure if every classification method will be evaluated on the same folds of X-Validation.. Is this guaranteed when the local random seed parameter of X-Validation is set to true?
Is there maybe an easier way to finding the best classifier for the given classification task automatically?
Many thanks in advance.
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Golf" width="90" x="112" y="75">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
<operator activated="true" class="loop" compatibility="5.3.013" expanded="true" height="76" name="Loop" width="90" x="313" y="75">
<parameter key="set_iteration_macro" value="true"/>
<parameter key="iterations" value="3"/>
<operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="179" y="30">
<parameter key="number_of_validations" value="4"/>
<parameter key="use_local_random_seed" value="true"/>
<operator activated="true" class="select_subprocess" compatibility="5.3.013" expanded="true" height="76" name="Select Subprocess (2)" width="90" x="159" y="30">
<parameter key="select_which" value="%{iteration}"/>
<operator activated="true" class="k_nn" compatibility="5.3.013" expanded="true" height="76" name="k-NN (2)" width="90" x="44" y="30"/>
<connect from_port="input 1" to_op="k-NN (2)" to_port="training set"/>
<connect from_op="k-NN (2)" from_port="model" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="naive_bayes" compatibility="5.3.013" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="46" y="30"/>
<connect from_port="input 1" to_op="Naive Bayes (2)" to_port="training set"/>
<connect from_op="Naive Bayes (2)" from_port="model" to_port="output 1"/>
</process>
<operator activated="true" class="decision_tree" compatibility="5.3.013" expanded="true" height="76" name="Decision Tree (2)" width="90" x="48" y="30"/>
<connect from_port="input 1" to_op="Decision Tree (2)" to_port="training set"/>
<connect from_op="Decision Tree (2)" from_port="model" to_port="output 1"/>
</process>
<connect from_port="training" to_op="Select Subprocess (2)" to_port="input 1"/>
<connect from_op="Select Subprocess (2)" from_port="output 1" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="259" y="30">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="output 1"/>
</process>
<connect from_op="Golf" from_port="output" to_op="Loop" to_port="input 1"/>
<connect from_op="Loop" from_port="output 1" to_port="result 1"/>
</process>
</process>
[ /code]
