<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="6.0.003" expanded="true" height="76" name="read XML" width="90" x="45" y="30"> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="5.3.002" expanded="true" height="60" name="Read Document (3)" width="90" x="45" y="30"> <parameter key="file" value="%{path}%{file}"/> <parameter key="extract_text_only" value="false"/> <parameter key="encoding" value="UTF-8"/> </operator> <operator activated="true" class="text:replace_tokens" compatibility="5.3.002" expanded="true" height="60" name="Replace Tokens (3)" width="90" x="180" y="30"> <list key="replace_dictionary"> <parameter key="(<Family )" value="<<>>$1"/> </list> </operator> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (3)" width="90" x="313" y="30"> <parameter key="mode" value="regular expression"/> <parameter key="expression" value="<<>>"/> </operator> <operator activated="true" class="text:window_document" compatibility="5.3.002" expanded="true" height="60" name="Window Document (3)" width="90" x="450" y="30"> <parameter key="window_length" value="1"/> <process expanded="true"> <connect from_port="segment" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_collection" compatibility="6.0.003" expanded="true" height="76" name="Loop Collection (3)" width="90" x="585" y="30"> <parameter key="set_iteration_macro" value="true"/> <process expanded="true"> <operator activated="true" class="branch" compatibility="6.0.003" expanded="true" height="76" name="Branch (4)" width="90" x="313" y="30"> <parameter key="condition_type" value="expression"/> <parameter key="condition_value" value="%{iteration}!=1"/> <process expanded="true"> <operator activated="true" class="text:write_document" compatibility="5.3.002" expanded="true" height="76" name="Write Document (3)" width="90" x="45" y="30"> <parameter key="encoding" value="UTF-8"/> </operator> <operator activated="true" class="handle_exception" compatibility="6.0.003" expanded="true" height="94" name="Handle Exception (3)" width="90" x="185" y="39"> <process expanded="true"> <operator activated="true" class="read_xml" compatibility="6.0.003" expanded="true" height="60" name="Read XML" width="90" x="112" y="30"> <enumeration key="xpaths_for_attributes"/> <list key="namespaces"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <connect from_port="in 1" to_op="Read XML" to_port="file"/> <connect from_op="Read XML" from_port="output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="print_to_console" compatibility="6.0.003" expanded="true" height="76" name="Print to Console (5)" width="90" x="124" y="39"> <parameter key="log_value" value="XML Error in element %{iteration}"/> </operator> <connect from_port="in 1" to_op="Print to Console (5)" to_port="through 1"/> <connect from_op="Print to Console (5)" from_port="through 1" to_port="out 2"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> </operator> <connect from_port="condition" to_op="Write Document (3)" to_port="document"/> <connect from_op="Write Document (3)" from_port="file" to_op="Handle Exception (3)" to_port="in 1"/> <connect from_op="Handle Exception (3)" from_port="out 1" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_port="single" to_op="Branch (4)" to_port="condition"/> <connect from_op="Branch (4)" from_port="input 1" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.0.003" expanded="true" height="76" name="Append" width="90" x="581" y="165"/> <connect from_op="Read Document (3)" from_port="output" to_op="Replace Tokens (3)" to_port="document"/> <connect from_op="Replace Tokens (3)" from_port="document" to_op="Tokenize (3)" to_port="document"/> <connect from_op="Tokenize (3)" from_port="document" to_op="Window Document (3)" to_port="document"/> <connect from_op="Window Document (3)" from_port="documents" to_op="Loop Collection (3)" to_port="collection"/> <connect from_op="Loop Collection (3)" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="read XML" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
