Hı I am trying lattice structure optimizatons. Actually I can do it.
I want to change lattice types such as 1,2,3,4 and than results compare but I dont have any difference.
If you know solution for this problem,can you help me?
Thank you
Hi @Busra ASlan
So you are changing the lattice type from 1 to 4. But you don't see any change in results...
Is it in structure or FE results you don't see any change?
Thanks @Prakash Pagadala
Actually I want to see in FE results, but also if it is possible I want to see in structure
I ran a sample model, I can see changes in structure.
Hı @Prakash Pagadala
Thank you for helping.
I am sharing my files for type 1,2,3,4. I think I made a mistake but I did not find it.
Maybe you can help me.
thank you.
I will check and update you soon. Since you are interested in the results, I will try to post the results ASAP!!
HI,
I tried on a test model and I see the difference in structure and results as well. But this is not happening in your case and the reason I think is of the design envelope.
I will write to Dev team about this for a better explanation. I am attaching a PPT with my test model.
Thank you @Prakash Pagadala
I will be waiting for your news. I hope so, my model results can be similar to your model
Hı @Prakash Pagadala,
Did you find a solution to my problem with Dev team?
Yeah, so tetra elements take only one type. Whereas Hexa elements are compatible for all types of the lattice.
I tried to make a hexa element using 3D-solid-map for mesh structure. And then I got a solution for 1,2,3 types but the analysis results are zero for 4 is a solution.
Can you help me?
Thank you @Prakash Pagadala I tried to make a hexa element using 3D-solid-map for mesh structure. And then I got a solution for 1,2,3 types but the analysis results are zero for 4 is a solution. Can you help me?
Can you share the .out file for the type 4 lattice optimization?
Of course @Prakash Pagadala
Looks like after optimization loads are not connected to any elements. Can you please check the same and update the loads?
