Hi, I've searched the forums for an answer to this question but I haven't found one yet.
I have a csv file which has 4 columns:
1) Id (used as a label)
2) Clustering attribute 1
3) Clustering attribute 2
4) Other information
The clustering attributes are the ones used in the actual clustering, while the other information is not used.
Currently, I have used the select attributes function to ensure that the clustering attributes are used for the clustering. However, in the write csv output of the clustering, I get only the following columns:
1) Id
4) Cluster that the ID belongs to
However, I need the 4th column (Other Information) that existed in the original dataset in the clustering output (even though its not used). Is there any way to do this?
Thanks very much in advance!
