Hı everyone,
I want the part of the model to contain a completely lattice structure. But my model are empty places.
Could you help me?
Hi @Aslan
Is it during the first phase or 2nd phase of optimization?
Can you share the files, please?
Hı @Prakash Pagadala
I shared my model. Could you see?
Yes, I have the files, thank you. I will check and get back to you.
Can you set the porosity to LOW and check if that helps?
I shared a file with you. Please run optimization and check the results.
Thank you @Prakash Pagadala
But the same problem occurred. I changed the constraint value that was used in the first phase. I hope it's true.
@Aslan
Which version are you using and what are the updates?
Please see the results which I got
I'm using the 2017.2 version.
I use volume fraction and the upper bound is 0.4 for constraint.
minimize compliance for objective.
Did you check my file?
Thank you.
