Hı,
I'm doing lattice structural optimizations. Lattice type 1 and 3 is working but 2 and 4 are not working. I get this error.
Can you help me?
Thank you.
can you share the entire .out file, please?
Of course @Prakash Pagadala
lattice type 4 is used in this file. The solution is working when using lattice type 1 and 3 with the same parameters.
Please try this file,
Somehow one of the fields on CONTACT card is wrongly formatted.
Hı @Prakash Pagadala,
I understand what is a mistake. But I can't run when I try myself on the first model. Which did you change parameter?
Hi @Busra ASlan
I didn't change anything related to optimization. But I removed the badly formatted line on the CONTACT card.
Thank you for your answer,
But I don't understand. How can I remove the badly formatted line on the CONTACT card?
I am sorry, can you tell me more clearly.
You can edit the deck in any text editor and compare the error message with Card image.
