<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="Subprocess" width="90" x="45" y="75"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="id" value="1"/> <parameter key="shopping" value=""egg""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="120"> <list key="attribute_values"> <parameter key="id" value="2"/> <parameter key="shopping" value=""meat""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="210"> <list key="attribute_values"> <parameter key="id" value="3"/> <parameter key="shopping" value=""vegetable""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="112" name="Append" width="90" x="246" y="75"/> <operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="75"> <list key="function_descriptions"> <parameter key="quantity" value="1"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Append" from_port="merged set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="pivot" compatibility="5.3.015" expanded="true" height="76" name="Pivot" width="90" x="179" y="75"> <parameter key="group_attribute" value="id"/> <parameter key="index_attribute" value="shopping"/> <parameter key="consider_weights" value="false"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.3.015" expanded="true" height="76" name="Rename by Replacing" width="90" x="313" y="75"> <parameter key="replace_what" value="quantity_(.*)"/> <parameter key="replace_by" value="$1"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.3.015" expanded="true" height="94" name="Replace Missing Values" width="90" x="447" y="75"> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="0"/> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="5.3.015" expanded="true" height="76" name="Numerical to Binominal" width="90" x="581" y="75"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|id"/> <parameter key="invert_selection" value="true"/> </operator> <connect from_op="Subprocess" from_port="out 1" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
