<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="false" class="read_excel" compatibility="5.3.008" expanded="true" height="60" name="Read Excel" width="90" x="45" y="120"> <parameter key="excel_file" value="urls.xls"/> <parameter key="imported_cell_range" value="A1:A2"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="locale" value="German"/> <list key="data_set_meta_data_information"> <parameter key="0" value="urls.true.attribute_value.attribute"/> </list> </operator> <operator activated="true" class="read_csv" compatibility="5.3.008" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="http://pastebin.com/raw.php?i=dchJNtxe"/> <parameter key="trim_lines" value="true"/> <parameter key="use_quotes" value="false"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="locale" value="German"/> <list key="data_set_meta_data_information"> <parameter key="0" value="urls.true.nominal.regular"/> </list> </operator> <operator activated="true" class="loop_values" compatibility="5.3.008" expanded="true" height="76" name="Loop Values" width="90" x="179" y="30"> <parameter key="attribute" value="urls"/> <process expanded="true"> <operator activated="true" class="web:read_rss" compatibility="5.3.001" expanded="true" height="60" name="Read RSS Feed" width="90" x="179" y="75"> <parameter key="url" value="%{loop_value}"/> <parameter key="random_user_agent" value="true"/> </operator> <connect from_op="Read RSS Feed" from_port="output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.3.008" expanded="true" height="76" name="Append" width="90" x="313" y="30"/> <connect from_op="Read CSV" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
