Hı,
I'm trying to optimize. But when I showed _lattice_optimze.fem at HyperWorks and _lattice_s1.h3d at hyperview , I see different structure. But I think they are same so I should see same structure.
Hi @Busra ASlan Can you please share the beam_lattice.fem (the output fem file after 1st phase of lattice optimization)
Of course @Prakash Pagadala
Hi @Busra ASlan
Thank you for sharing the file.
After phase 1 you have a .fem which is beam_lattice.fem. When you proceed to phase 2 optimization you will have another file beam_lattice_optimized.fem which will be size optimized and this will be your final lattice structure. Please analyze the same and check the results.
I understand that after phase 2 optimization, the structure is not the same as lattice_optimized.fem but same as the phase 1 output. I will raise a ticket for the same.
Thank you @Prakash Pagadala
I will try and check again. I hope so I will get a good result:)
