<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="5.3.008" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="http://pastebin.com/raw.php?i=9650xSRN"/> <parameter key="use_quotes" value="false"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"> <parameter key="0" value="group.true.polynominal.attribute"/> <parameter key="1" value="index.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="has" value="TRUE"/> </list> </operator> <operator activated="true" class="pivot" compatibility="5.3.008" expanded="true" height="76" name="Pivot" width="90" x="313" y="30"> <parameter key="group_attribute" value="group"/> <parameter key="index_attribute" value="index"/> <parameter key="consider_weights" value="false"/> <parameter key="skip_constant_attributes" value="false"/> <parameter key="datamanagement" value="boolean_array"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.3.008" expanded="true" height="94" name="Replace Missing Values" width="90" x="447" y="30"> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="false"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
