setParameter Problems
User: "aleatorio"
New Altair Community Member
Updated by Jocelyn
Hi, I´m creating a sample operator with balanced data, but when I want to set the parameter PARAMETER_SAMPLE_RATIO_LIST i don´t know how to do it.I want to take all the example that has the label=good  and half of label=bad so the values would be: good-> 1.0 and bad -> 0.5.How should I set this parameter.
My code is:
public ExampleSet randomSampling(ExampleSet ES,String ProcessPath){
      try{
                Operator op= OperatorService.createOperator(SamplingOperator.class);
                op.setParameter(SamplingOperator.PARAMETER_SAMPLE, "relative");
                op.setParameter(SamplingOperator.PARAMETER_BALANCE_DATA, "true");
                op.setParameter(SamplingOperator.PARAMETER_SAMPLE_RATIO_LIST, "good, 1.0");
                op.getInputPorts().getPortByIndex(0).receive(ES);
                op.doWork();
                ExampleSet result=null;
                if(op.getOutputPorts().getPortByIndex(0).getAnyDataOrNull() instanceof ExampleSet)
                    result=(ExampleSet) op.getOutputPorts().getPortByIndex(0).getAnyDataOrNull();
                return result;
            }catch(OperatorCreationException | OperatorException e){
                System.out.println(e);
                return null;
1 - 2 of 21
    User: "Marco_Boeck"
    you can use a List<String> as the parameter vaue.
    Marco
    User: "aleatorio"
    OP
    Thanks a lot  ;D.
    I didn´t realice about that, i was able to make it work with your help.
