<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.004"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.004" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.004" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="weka:W-J48" compatibility="5.3.001" expanded="true" height="76" name="W-J48" width="90" x="179" y="30"/> <operator activated="true" class="execute_script" compatibility="6.0.004" expanded="true" height="76" name="Execute Script" width="90" x="313" y="30"> <parameter key="script" value="import com.rapidminer.operator.learner.weka.WekaClassifier; import weka.classifiers.trees.J48; import com.rapidminer.tools.LogService; import java.util.logging.Level; WekaClassifier classifier = (WekaClassifier)input[0]; J48 j48 = classifier.getClassifier(); LogService.getRoot().log(Level.INFO, "WEKA TREE SIZE: "+j48.measureTreeSize()); LogService.getRoot().log(Level.INFO, "WEKA LEAF NUMBER: "+j48.measureNumLeaves()); return input[0];"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="W-J48" to_port="training set"/> <connect from_op="W-J48" from_port="model" to_op="Execute Script" to_port="input 1"/> <connect from_op="Execute Script" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
