I need to run a RapidMiner process in Java. Like explained in this link :
http://stackoverflow.com/questions/15834182/integration-of-rapidminer-in-java-application,
import com.rapidminer.Process;
import com.rapidminer.RapidMiner;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.operator.io.ExcelExampleSource;
import com.rapidminer.tools.XMLException;
import java.io.File;
import java.io.IOException;
import java.lang.Object;
public class ReadRapidminerProcess {
public static void main(String[] args) {
try {
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process process = new Process(new File("C:\\Users\\Keshav\\.RapidMiner5\\repositories\\Local Repository\\lsvmtest.rmp"));
process.run();
} catch (IOException | XMLException | OperatorException ex) {
ex.printStackTrace();
I run the above code. The code compiled but gave following error during its run:
Mar 28, 2014 3:05:23 AM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Mar 28, 2014 3:05:23 AM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Mar 28, 2014 3:05:23 AM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying base directory of classes (build) 'null'...failed
Mar 28, 2014 3:05:23 AM com.rapid_i.deployment.update.client.ManagedExtension readConfiguration
WARNING: Failed to read global extension state: java.io.IOException: Property rapidminer.home is not set
at com.rapidminer.tools.FileSystemService.getRapidMinerHome(FileSystemService.java:93)
at com.rapidminer.tools.FileSystemService.getLibraryFile(FileSystemService.java:99)
at com.rapidminer.tools.plugin.Plugin.getPluginLocation(Plugin.java:1113)
at com.rapid_i.deployment.update.client.ManagedExtension.getGlobalExtensionsDir(ManagedExtension.java:172)
at com.rapid_i.deployment.update.client.ManagedExtension.readConfiguration(ManagedExtension.java:257)
at com.rapid_i.deployment.update.client.ManagedExtension.init(ManagedExtension.java:349)
at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:941)
at com.rapidminer.RapidMiner.init(RapidMiner.java:550)
at ReadRapidminerProcess.main(ReadRapidminerProcess.java:16)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at edu.rice.cs.drjava.model.compiler.JavacCompiler.runCommand(JavacCompiler.java:272)
at edu.rice.cs.dynamicjava.symbol.JavaClass$JavaMethod.evaluate(JavaClass.java:362)
at edu.rice.cs.dynamicjava.interpreter.ExpressionEvaluator.handleMethodCall(ExpressionEvaluator.java:92)
at edu.rice.cs.dynamicjava.interpreter.ExpressionEvaluator.visit(ExpressionEvaluator.java:84)
at koala.dynamicjava.tree.StaticMethodCall.acceptVisitor(StaticMethodCall.java:121)
at edu.rice.cs.dynamicjava.interpreter.ExpressionEvaluator.value(ExpressionEvaluator.java:38)
at edu.rice.cs.dynamicjava.interpreter.ExpressionEvaluator.value(ExpressionEvaluator.java:37)
at edu.rice.cs.dynamicjava.interpreter.StatementEvaluator.visit(StatementEvaluator.java:106)
at edu.rice.cs.dynamicjava.interpreter.StatementEvaluator.visit(StatementEvaluator.java:29)
at koala.dynamicjava.tree.ExpressionStatement.acceptVisitor(ExpressionStatement.java:101)
at edu.rice.cs.dynamicjava.interpreter.StatementEvaluator.evaluateSequence(StatementEvaluator.java:66)
at edu.rice.cs.dynamicjava.interpreter.Interpreter.evaluate(Interpreter.java:77)
at edu.rice.cs.dynamicjava.interpreter.Interpreter.interpret(Interpreter.java:47)
at edu.rice.cs.drjava.model.repl.newjvm.InterpreterJVM.interpret(InterpreterJVM.java:246)
at edu.rice.cs.drjava.model.repl.newjvm.InterpreterJVM.interpret(InterpreterJVM.java:220)
at sun.rmi.server.UnicastServerRef.dispatch(Unknown Source)
at sun.rmi.transport.Transport$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Mar 28, 2014 3:05:23 AM com.rapidminer.tools.plugin.Plugin initAll
WARNING: None of the properties rapidminer.init.plugins and rapidminer.home is set. No globally installed plugins will be loaded.
Mar 28, 2014 3:05:23 AM com.rapid_i.deployment.update.client.ManagedExtension getManagedExtensionsDirectories
WARNING: None of the properties rapidminer.init.plugins and rapidminer.home is set. No globally installed extensions will be loaded.
Mar 28, 2014 3:05:23 AM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Text Processing
INFO: Register plugin: Web Mining
Mar 28, 2014 3:05:25 AM com.rapidminer.tools.OperatorService parseOperators
SEVERE: Failed to register operator: RapidMiner Core : hierarchical_classification
java.lang.AssertionError
at com.rapidminer.operator.ports.impl.AbstractInputPort.receiveMD(AbstractInputPort.java:80)
at com.rapidminer.operator.ports.metadata.ExampleSetPrecondition.assumeSatisfied(ExampleSetPrecondition.java:86)
at com.rapidminer.operator.Operator.assumePreconditionsSatisfied(Operator.java:2130)
at com.rapidminer.operator.OperatorChain.assumePreconditionsSatisfied(OperatorChain.java:502)
at com.rapidminer.tools.OperatorService.registerOperator(OperatorService.java:520)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:301)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:293)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:269)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:231)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:204)
at com.rapidminer.tools.OperatorService.init(OperatorService.java:133)
at com.rapidminer.RapidMiner.init(RapidMiner.java:559)
SEVERE: Failed to register operator: RapidMiner Core : fixedsplitvalidation
at com.rapidminer.operator.ports.metadata.SimplePrecondition.assumeSatisfied(SimplePrecondition.java:90)
SEVERE: Failed to register operator: RapidMiner Core : conditionedfeaturegeneration
Can someone please help out with the code?
Keshav
PS: The amount of errors displayed was very large - due to the space constraint of 20,000 characters,I pasted only a part of the error message.
