<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="loop" compatibility="6.0.002" expanded="true" height="76" name="Loop" width="90" x="246" y="210"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="2"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="6.0.002" expanded="true" height="60" name="Read Excel" width="90" x="179" y="120"> <parameter key="excel_file" value="d:\tmp\loopBook.xlsx"/> <parameter key="sheet_number" value="%{iteration}"/> <parameter key="imported_cell_range" value="A1:C2"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.integer.attribute"/> <parameter key="1" value="att2.true.integer.attribute"/> <parameter key="2" value="att3.true.integer.attribute"/> </list> </operator> <connect from_op="Read Excel" from_port="output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
