I am working on text classification project, I was trying to integrate the model I built in Rapidminer GUI but I have problems in the code which I couldn't solve to move on!
- I'm using rapid miner 5.3.015
- I added all rapid miner jars to the netbean project
- I am beginner user.
- here is my xml file:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files (3)" width="90" x="179" y="75">
<list key="text_directories">
<parameter key="Tourist" value="W:\NormalizedFiles\TouristAndTravel"/>
<parameter key="Science" value="W:\NormalizedFiles\Science"/>
</list>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (3)" width="90" x="45" y="30"/>
<operator activated="true" class="text:filter_stopwords_arabic" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (3)" width="90" x="180" y="30"/>
<operator activated="true" class="text:stem_arabic" compatibility="5.3.002" expanded="true" height="60" name="Stem (3)" width="90" x="409" y="30"/>
<connect from_port="document" to_op="Tokenize (3)" to_port="document"/>
<connect from_op="Tokenize (3)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
<connect from_op="Filter Stopwords (3)" from_port="document" to_op="Stem (3)" to_port="document"/>
<connect from_op="Stem (3)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="parallel:x_validation_parallel" compatibility="5.3.000" expanded="true" height="112" name="KNNValidation" width="90" x="449" y="30">
<operator activated="true" class="k_nn" compatibility="5.3.015" expanded="true" height="76" name="k-NN" width="90" x="102" y="30"/>
<connect from_port="training" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="5.3.015" expanded="true" height="76" name="Performance (2)" width="90" x="187" y="30"/>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Process Documents from Files (3)" to_port="word list"/>
<connect from_op="Process Documents from Files (3)" from_port="example set" to_op="KNNValidation" to_port="training"/>
<connect from_op="KNNValidation" from_port="model" to_port="result 1"/>
</process>
</process>
and here is my initial trials:
Following the API documentation:
public static void main(String[] args) {
try {
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process process = new Process(new File("W:/RapidMinerRepository/textKNNClassifier.rmp"));
process.run();
} catch (IOException | XMLException | OperatorException ex) {
ex.printStackTrace();
In this code there is no editor errors but it showed me this error: com.rapidminer.parameter.UndefinedParameterError: A value for the parameter 'operatorName' must be specified!
So, I couldn't figure where is the problem exactly!
Another trial following this thread:
http://rapid-i.com/rapidforum/index.php/topic,3862.msg14364.html#msg14364
public static void main(String[] args) throws MalformedRepositoryLocationException, RepositoryException {
// this initializes RapidMiner with your repositories available
RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE);
RapidMiner.init();
// loads the process from the repository
RepositoryLocation pLoc = new RepositoryLocation("W:/RapidMinerRepository/textKNNClassifier.rmp");
ProcessEntry pEntry = (ProcessEntry) pLoc.locateEntry();
String processXML = pEntry.retrieveXML();
Process myProcess = new Process(processXML); //error
// execute the process and get the resulting objects
IOContainer ioInput = new IOContainer(new IOObject[] {myIOObject});
myProcess.run(); //error
errors shown by netbean editor are for words creating Process object and calling run() method
So, any idea how to solve this problem?
Thanks in advance
