Frequency Response Analysis
Jebunderscore
Jebunderscore Altair Community Member
Hi, I must perfom a Frequency Response Analysis.
In particular i've a pressurized cylinder subject to a Impulse load with frequency of 1 Hz and magnitude 0 - 3000 psi - 0 (sin function load).
i want the response on first 5 natural modal frequency.
how i must set the analysis ?
Thank you
Welcome!
  • Altair Forum User
    Altair Forum User
    edited November 2020
    Hi @Fabiano.Pagliarini Here is a sample tutorial for Modal frequency analysis. This should help you to model FRF deck.
  • Jebunderscore
    edited October 2017
    Hi @Prakash Pagadala. I know this tutorial.
    I ve 2 problems:
    1) I want to apply a unifom pressure on a surfarce with about 30000 nodes (my model is similar to a pressurized cylinder) in normal direction . Is it possible this thing in DAREA card?
    2) How can I apply my semi-sin load (0 - 3000 psi - 0 @ 1 Hz) on TABLED1?
    Thank you
  • Altair Forum User
    Altair Forum User
    edited October 2017
    yes you can use pressure as load type which can be refereed in RLOAD# card.
    I am trying to understand the loading. SO is it like at 0Hz the load is zero, at 1 it is 3000 and at 1 it is again zero?
    If the above is correct then it cannot be a sine wave. Can you provide the right curve values.
  • Jebunderscore
    edited October 2017
    Prakash Pagadala,
    the load spectrum in time domain is:
    0 psi @ t=0 sec;
    3000 psi @ t=1 sec;
    0 psi @ t=2 sec.
    What I put on TABLED1 and DAREA?
    In DAREA, i can not allocate the pressure (3000 psi) in right way, because there isn't the possibility (i'm not expert in dynamic analyzes !)
    to assign a pressure on a cylindrical coord system (in radial direction) or normal to sufaces.
    is it possible to use a generic PLOAD4 to assign this pressure and refer it on RLOAD card?
    Thank's for your support.
  • Altair Forum User
    Altair Forum User
    edited October 2017
    You can use PLOAD4 in RLOAD. RLOAD is supports PLOADx as excited load. You can give PLOAD as 1 and provide the 3000 factor in tabled1
  • Jebunderscore
    edited October 2017
    thank you @Prakash Pagadala
  • Altair Forum User
    Altair Forum User
    edited October 2017
    No Problem. Please let us know if you face any road blocks during the simulation and we will do our best to help you out :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Welcome!
Welcome!
