Oh man I've been having the same issue. Now I keep getting a blank report but here's what I did- drag your dataset to the process design panel, or drag a read csv/ read excep operator -> Generate Reports operator -> Reports operator. Make sure that the name of the report in both Generate Reports and Reports is same. Select the type of report you want in Generate Reports and provide a suitable location for the output. Under the parameters for Report operator, click Configure Report and Select Reportable Type - "Data Table", Select Reportable View - "Metadata View".
In theory this should work. But I keep getting a blank report everytime. Why is RapidMiner never very straightforward!?!?! :smileymad::womanmad::manmad::catmad:
The Reporting extension is a bit clunky and hard to use. It's from the v5.3 era where things weren't as streamlined as they are now. It does need to be updated but there is no timeline to do that.
If the general Aggregate operator doesn't work for you, have you checked out the Generate Aggregation operator? It allows you to do statistics across examples (rows).
