Hi everyone,
I'm trying to test Rapidminer as a web service, but first I created a simple class in order to test the code as an standalone application. The class, named RMin_prova, has the following method:
public void prova() {
try {
IOContainer ioInput = null;
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process pr = new Process(new File(nomFitxerDades));
Operator op = pr.getOperator("Read Excel");
op.setParameter(ExcelExampleSource.PARAMETER_EXCEL_FILE,"C:\\Users\\Serpc\\Desktop\\Dades\\BD_FINAL1.xls");
ioResult = pr.run(ioInput);
} catch (IOException | XMLException | OperatorException ex) {
Logger.getLogger(RMin_prova.class.getName()).log(Level.SEVERE, null, ex);
I call this class/method in another project through the code:
RMin_prova prueba = new RMin_prova();
prueba.prova();
and it works perfectly. Then I used the same code in a soap web service like that:
@WebMethod(operationName = "linear_regression")
public void linear_regression(@WebParam(name = "name") String nomFitxer) throws InvocationTargetException {
prueba.prova();
but it doesn't work. I test it through the Glassfish server with Netbeans and the browser, that it returns the message:
Exceptions details : java.lang.reflect.InvocationTargetException
javax.servlet.ServletException: java.lang.reflect.InvocationTargetException at org.glassfish.webservices.monitoring.WebServiceTesterServlet.doPost(WebServiceTesterServlet.java:342) at org.glassfish.webservices.monitoring.WebServiceTesterServlet.invoke(WebServiceTesterServlet.java:106) at org.glassfish.webservices.JAXWSServlet.doPost(JAXWSServlet.java:157) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1682) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:318) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:160) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:734) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:673) at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:99) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:174) at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:416) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:283) at com.sun.enterprise.v3.services.impl.ContainerMapper$HttpHandlerCallable.call(ContainerMapper.java:459) at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:167) at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:206) at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:180) at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:235) at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:283) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:200) at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:132) at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:111) at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77) at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:536) at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:112) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:117) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:56) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:137) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:591) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:571) at java.lang.Thread.run(Thread.java:745) Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.glassfish.webservices.monitoring.WebServiceTesterServlet.doPost(WebServiceTesterServlet.java:313) ... 32 more Caused by: com.sun.xml.ws.fault.ServerSOAPFaultException: Client received SOAP Fault from server: java.lang.NoSuchMethodException: java.lang.NoClassDefFoundError.getTargetException() Please see the server log to find more detail regarding exact cause of the failure. at com.sun.xml.ws.fault.SOAP11Fault.getProtocolException(SOAP11Fault.java:193) at com.sun.xml.ws.fault.SOAPFaultBuilder.createException(SOAPFaultBuilder.java:128) at com.sun.xml.ws.client.sei.StubHandler.readResponse(StubHandler.java:253) at com.sun.xml.ws.db.DatabindingImpl.deserializeResponse(DatabindingImpl.java:203) at com.sun.xml.ws.db.DatabindingImpl.deserializeResponse(DatabindingImpl.java:290) at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:119) at com.sun.xml.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:92) at com.sun.xml.ws.client.sei.SEIStub.invoke(SEIStub.java:161) at com.sun.proxy.$Proxy318.linearRegression(Unknown Source) ... 37 moreI've observed that the problem is due to the line:
RapidMiner.init();
If I remove that line I have no errors, but obviously the process doesn't work.
I'm using Rapidminer 5.3 as this first tests will be under the AGPL.
The same web service code works when I tried to test Weka code.
Any idea? Thanks in advance.
cesc
