<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.2.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.2.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="7.2.000-SNAPSHOT" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="45" y="34"> <list key="attribute_values"> <parameter key="Test" value="%{_ra_user}"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="store" compatibility="7.2.000-SNAPSHOT" expanded="true" height="68" name="Store" width="90" x="179" y="34"> <parameter key="repository_entry" value="UserLoggedInTest"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Store" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
