Hi
I have problems with running rapidminer from Eclipse. The error is:
May 01, 2016 1:25:46 AM com.rapidminer.tools.ParameterService init
Message: Reading configuration resource com/rapidminer/resources/rapidminerrc.
May 01, 2016 1:25:46 AM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
May 01, 2016 1:25:46 AM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying base directory of classes (build) 'E:\yuanshuai\lab\thesis\rapidminer-5-master'...gotcha!
May 01, 2016 1:25:46 AM com.rapidminer.repository.RepositoryManager load
INFO: Cannot access file system in execution mode UNKNOWN. Not loading repositories.
May 01, 2016 1:25:48 AM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
May 01, 2016 1:25:49 AM com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403
May 01, 2016 1:25:49 AM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
May 01, 2016 1:25:49 AM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
[Fatal Error] :1:1: Premature end of file.
I used the version "rapidminer-5" from github.
Any one know how to deal with this?
Thank you
