Martin Schmitz wrote:If its always 4 chars, 5 chars 5 chars you might simply use Generate Attributes with cut?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.1.000-BETA"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.1.000-BETA" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="7.1.000-BETA" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="85"> <list key="attribute_values"> <parameter key="myData" value=""A002W0541G001""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="7.1.000-BETA" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="112" y="187"> <list key="attribute_values"> <parameter key="myData" value=""A02202W0541G001G002231""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="7.1.000-BETA" expanded="true" height="103" name="Append" width="90" x="313" y="85"> <parameter key="datamanagement" value="double_array"/> <parameter key="merge_type" value="all"/> </operator> <operator activated="true" class="split" compatibility="7.1.000-BETA" expanded="true" height="82" name="Split" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="myData"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value="(?<=[0-9]++)(.*?)(?=[A-Z])"/> <parameter key="split_mode" value="ordered_split"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
JEdward wrote:It sounds like you just need the right RegEx. Assuming you have a pattern of [Letter+Numbers][Letter+Numbers] then this works: "(?<=[0-9]++)(.*?)(?=[A-Z])"Negative lookbehind to check there are numbers before, lookahead to check for the letter. Anything inbetween is used to split.
