<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="30"> <parameter key="text" value="This is an iphone test data"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document (3)" width="90" x="45" y="120"> <parameter key="text" value="This is an iphone test data set with htc"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.3.002" expanded="true" height="112" name="Process Documents (2)" width="90" x="380" y="30"> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="30"/> <operator activated="true" breakpoints="after" class="text:filter_tokens_by_content" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="246" y="30"> <parameter key="condition" value="matches"/> <parameter key="regular_expression" value="iphone|galaxy|htc|xperia|screen|ram|able|i"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (2)" width="90" x="393" y="30"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Filter Tokens (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents (2)" to_port="documents 1"/> <connect from_op="Create Document (3)" from_port="output" to_op="Process Documents (2)" to_port="documents 2"/> <connect from_op="Process Documents (2)" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
