<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="7.0.001" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="34"> <list key="attribute_values"> <parameter key="Value" value=""1 ~ 2""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="replace" compatibility="7.0.001" expanded="true" height="82" name="Replace" width="90" x="246" y="34"> <parameter key="replace_what" value="~"/> <parameter key="replace_by" value="-"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
