<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="multiply" compatibility="6.5.002" expanded="true" height="94" name="Multiply" width="90" x="179" y="75"/> <operator activated="true" class="filter_examples" compatibility="6.5.002" expanded="true" height="94" name="Filter Examples (2)" width="90" x="313" y="210"> <list key="filters_list"> <parameter key="filters_entry_key" value="Play.equals.no"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="6.5.002" expanded="true" height="94" name="Filter Examples" width="90" x="313" y="30"> <list key="filters_list"> <parameter key="filters_entry_key" value="Play.equals.yes"/> </list> </operator> <operator activated="true" class="sample" compatibility="6.5.002" expanded="true" height="76" name="Sample" width="90" x="447" y="30"> <parameter key="sample_size" value="5"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> </operator> <operator activated="true" class="append" compatibility="6.5.002" expanded="true" height="94" name="Append" width="90" x="514" y="120"/> <connect from_op="Retrieve Golf" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
