RapidMiner/Netbeans Integration problem!
Hello guys,
I have a serioous issue and i need your help...I've created a calss in my program which creates a rapidminer model by adding each operator of rapidminer directly in netbeans rather than loading a complete model from rapidminer program. But now i get an error which looks like that :
Rmtest 0
Dec 08, 2013 10:25:00 PM youcomment.gui btRMtestActionPerformed
SEVERE: null
com.rapidminer.operator.OperatorCreationException: No operator description object given for 'com.rapidminer.operator.text.io.FileDocumentInputOperator'
at com.rapidminer.tools.OperatorService.createOperator(OperatorService.java:687)
at youcomment.RapidM.runthisthingy(RapidM.java:96)
at youcomment.gui.btRMtestActionPerformed(gui.java:217)
so actually the error appears after i print the "Rmtest 0" thing...in this line of code i suppose:
" FileDocumentInputOperator processdocumentfromfiles1 = OperatorService.createOperator(FileDocumentInputOperator.class)"
I add the whole class i made...pls help me out here i am not an expert java programmer but i am trying to learn!!! thank you a lot...
package youcomment;
import com.rapidminer.Process;
import com.rapidminer.RapidMiner;
import com.rapidminer.RapidMiner.ExecutionMode;
import com.rapidminer.example.Attribute;
import com.rapidminer.example.Example;
import com.rapidminer.example.ExampleSet;
import com.rapidminer.example.table.ExampleTable;
import com.rapidminer.operator.ExecutionUnit;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.ModelApplier;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorCreationException;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.operator.performance.PerformanceEvaluator;
import com.rapidminer.operator.validation.XValidation;
import com.rapidminer.operator.text.io.*;
import com.rapidminer.operator.learner.bayes.NaiveBayes;
import com.rapidminer.operator.performance.BinominalClassificationPerformanceEvaluator;
import com.rapidminer.tools.OperatorService;
import com.rapidminer.operator.text.io.DocumentLoader;
import com.rapidminer.operator.text.io.DocumentTextInputOperator;
import com.rapidminer.operator.text.io.tokenizer.StringTokenizerOperator;
import com.rapidminer.operator.text.io.transformer.CaseTransformationOperator;
import java.io.*;
import java.util.List;
import java.util.LinkedList;
public class RapidM {
* Connect the output-port
* <code>fromPortName</code> from Operator
* <code>from</code> with the input-port
* <code>toPortName</code> of Operator
* <code>to</code>.
private static void connect(Operator from, String fromPortName, Operator to, String toPortName) {
from.getOutputPorts().getPortByName(fromPortName).connectTo(to.getInputPorts().getPortByName(toPortName));
* <code>fromPortName</code> from Subprocess
* <code>to</code>.
private static void connect(ExecutionUnit from, String fromPortName,
from.getInnerSources().getPortByName(fromPortName).connectTo(
* <code>toPortName</code> of Subprocess
* <code>to</code>.
ExecutionUnit to, String toPortName) throws OperatorCreationException, IOException, OperatorException {
to.getInnerSinks().getPortByName(toPortName));}
public void runthisthingy() throws OperatorCreationException, IOException, OperatorException{
//initialiaze rapiminer
// set properties to point to plugin directory
String pluginDirString = new File("C:\\Program_Files\\Rapid-I\\RapidMiner5\\lib\\plugins").getAbsolutePath();
System.setProperty(RapidMiner.PROPERTY_RAPIDMINER_INIT_PLUGINS_LOCATION, pluginDirString);
RapidMiner.setExecutionMode(ExecutionMode.EMBEDDED_WITHOUT_UI);
RapidMiner.init();
// Create a process
Process process = new Process();
// Set the parameters of process
process.getRootOperator().setParameter("parallelize_main_process", "true");
process.getRootOperator().setParameter("encoding", "UTF-8");
// all operators from "left to right"
System.out.println("Rmtest 0");
//Process documents from files
FileDocumentInputOperator processdocumentfromfiles1 = OperatorService.createOperator(FileDocumentInputOperator.class);
System.out.println("Rmtest 1");
//set textlist of Process documents from files
List<String[]> textList1 = new LinkedList<String[]>();
textList1.add(new String[]{"Positive", "positive"});
textList1.add(new String[]{"Negative", "negative"});
System.out.println("Rmtest 2");
System.out.println("Rmtest 3");
System.out.println("Rmtest 4");
// Set the parameters of Process documents from files 1
processdocumentfromfiles1.setListParameter("text_directories", textList1);
processdocumentfromfiles1.setParameter("encoding", "UTF-8");
processdocumentfromfiles1.setParameter("vector_creation", "TF-IDF");
processdocumentfromfiles1.setParameter("prune_method", "absolute");
processdocumentfromfiles1.setParameter("prune_below_absolute", "2");
processdocumentfromfiles1.setParameter("prune_above_absolute", "999");
processdocumentfromfiles1.setParameter("parallelize_vector_creation","true");
//X-validation
XValidation xvalidation = OperatorService.createOperator(XValidation.class);
// Set the parameters of X-validation
xvalidation.setParameter(XValidation.PARAMETER_NUMBER_OF_VALIDATIONS, Integer.valueOf(10).toString());
xvalidation.setParameter("parallelize_training", "true");
xvalidation.setParameter("parallelize_testing", "true");
//Operators inside the validation
NaiveBayes naivebayes = OperatorService.createOperator(NaiveBayes.class);
//naivebayes.setParameter("training_cycles", "500");
//RandomForestLearner ManolisRF=OperatorService.createOperator(RandomForestLearner.class);
Operator modelApplier = OperatorService.createOperator(ModelApplier.class);
BinominalClassificationPerformanceEvaluator performance = OperatorService.createOperator(BinominalClassificationPerformanceEvaluator.class);
FileDocumentInputOperator processdocumentfromfiles2 = OperatorService.createOperator(FileDocumentInputOperator.class);
List<String[]> textList2 = new LinkedList<String[]>();
textList2.add(new String[]{"Unlabeled", "unlabeled"});
// Set the parameters of Process documents from files 2
processdocumentfromfiles2.setListParameter("text_directories", textList2);
processdocumentfromfiles2.setParameter("encoding", "UTF-8");
processdocumentfromfiles2.setParameter("vector_creation", "TF-IDF");
processdocumentfromfiles2.setParameter("prune_method", "absolute");
processdocumentfromfiles2.setParameter("prune_below_absolute", "2");
processdocumentfromfiles2.setParameter("prune_above_absolute", "999");
processdocumentfromfiles2.setParameter("parallelize_vector_creation","true");
// add operators to the main process and connect them
process.getRootOperator().getSubprocess(0).addOperator(processdocumentfromfiles1);
process.getRootOperator().getSubprocess(0).addOperator(xvalidation);
connect(processdocumentfromfiles1, "example set", xvalidation, "training");
//operators inside the process documents from files 1
StringTokenizerOperator tokenize1 = OperatorService.createOperator(StringTokenizerOperator.class);
CaseTransformationOperator tranformcases1 = OperatorService.createOperator(CaseTransformationOperator.class);
// add operators to the process documents from files and connect them
processdocumentfromfiles1.getSubprocess(0).addOperator(tokenize1);
processdocumentfromfiles1.getSubprocess(0).addOperator(tranformcases1);
connect(processdocumentfromfiles1.getSubprocess(0), "document", tokenize1, "document");
connect(tokenize1, "document", tranformcases1, "document");
connect(tranformcases1, "document", processdocumentfromfiles1.getSubprocess(0), "document 1");
// xvalidation
// training part of xvalidation
xvalidation.getSubprocess(0).addOperator(naivebayes);
//xvalidation.getSubprocess(0).addOperator(ManolisRF);
// create connection within training process: from left to right ...
connect(xvalidation.getSubprocess(0), "training", naivebayes, "training set");
//connect(xvalidation.getSubprocess(0), "training", ManolisRF,"training set");
connect(naivebayes, "model", xvalidation.getSubprocess(0), "model");
//connect(ManolisRF, "model", modelWriter, "input");
// testing part of xvalidation
xvalidation.getSubprocess(1).addOperator(modelApplier);
xvalidation.getSubprocess(1).addOperator(performance);
// create connection within testing process: from left to right ...
connect(xvalidation.getSubprocess(1), "model", modelApplier, "model");
connect(xvalidation.getSubprocess(1), "test set", modelApplier, "unlabelled data");
connect(modelApplier, "labelled data", performance, "labelled data");
connect(performance, "performance", xvalidation.getSubprocess(1), "averagable 1");
process.getRootOperator().getSubprocess(0).addOperator(processdocumentfromfiles2);
connect(processdocumentfromfiles1, "word list", processdocumentfromfiles2, "word list");
StringTokenizerOperator tokenize2 = OperatorService.createOperator(StringTokenizerOperator.class);
CaseTransformationOperator tranformcases2 = OperatorService.createOperator(CaseTransformationOperator.class);
processdocumentfromfiles2.getSubprocess(0).addOperator(tokenize2);
processdocumentfromfiles2.getSubprocess(0).addOperator(tranformcases2);
connect(processdocumentfromfiles2.getSubprocess(0), "document", tokenize2, "document");
connect(tokenize2, "document", tranformcases2, "document");
connect(tranformcases2, "document", processdocumentfromfiles2.getSubprocess(0), "document 1");
process.getRootOperator().getSubprocess(0).addOperator(modelApplier);
connect(processdocumentfromfiles2, "example set", modelApplier, "unlabelled data");
connect(xvalidation, "model", modelApplier, "model");
connect(modelApplier, "labelled data", process.getRootOperator().getSubprocess(0), "result 1");
connect(modelApplier, "model", process.getRootOperator().getSubprocess(0), "result 2");
// print process setup
//System.out.println(process.getRootOperator().createProcessTree(0));
File x = new File("Final.rmp");
process.save(x);
// perform process
//process.run();
IOContainer ioResult = process.run();
