Hello guys,
I am jsut getting familiar with macros. I am using the following workflow that I have taken from myexperiment. My problem is that it works for one single value and for all. The idea here is the following: I have a similarity matrix: id1,id2, similar. I want tofind the top 10 most similar items to a certain item(=id1). The following process works if i set the id in the xml. How can I make this work for all the id?
Thank you in advance.
Best,
Elena
P.S.: Is there a more concrete manual of macros in RM? I haven't found anything,
<process version="5.3.015">
<context>
<input/>
<output/>
<macros>
<macro>
<key>id</key>
<value>1599_1350505843.jpg</value>
</macro>
<macro>
<key>recommendation_no</key>
<value>10</value>
</macro>
</macros>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Similarity2_0.01" width="90" x="45" y="30">
<parameter key="repository_entry" value="//MyNewRepos/workflows/Improved/Similarity2_0.01"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="30">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="FIRST_ID=%{id}"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (2)" width="90" x="313" y="120">
<parameter key="parameter_string" value="SECOND_ID=%{id}"/>
<operator activated="true" class="rename" compatibility="5.3.015" expanded="true" height="76" name="Rename" width="90" x="447" y="120">
<parameter key="old_name" value="FIRST_ID"/>
<parameter key="new_name" value="temp"/>
<list key="rename_additional_attributes">
<parameter key="SECOND_ID" value="FIRST_ID"/>
<parameter key="temp" value="SECOND_ID"/>
</list>
<operator activated="true" class="append" compatibility="5.3.015" expanded="true" height="94" name="Append" width="90" x="581" y="30"/>
<operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="715" y="30">
<parameter key="attribute" value="FIRST_ID"/>
<operator activated="true" class="rename" compatibility="5.3.015" expanded="true" height="76" name="Rename (2)" width="90" x="849" y="30">
<parameter key="old_name" value="SECOND_ID"/>
<parameter key="new_name" value="recommendation"/>
<parameter key="DISTANCE" value="score"/>
</list>
<operator activated="true" class="sort" compatibility="5.3.015" expanded="true" height="76" name="Sort" width="90" x="983" y="30">
<parameter key="attribute_name" value="score"/>
<parameter key="sorting_direction" value="decreasing"/>
<operator activated="true" class="filter_example_range" compatibility="5.3.015" expanded="true" height="76" name="Filter Example Range" width="90" x="1117" y="30">
<parameter key="first_example" value="1"/>
<parameter key="last_example" value="%{recommendation_no}"/>
<connect from_op="Retrieve Similarity2_0.01" from_port="output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Append" to_port="example set 1"/>
<connect from_op="Filter Examples" from_port="original" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_op="Append" to_port="example set 2"/>
<connect from_op="Append" from_port="merged set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Rename (2)" to_port="example set input"/>
<connect from_op="Rename (2)" from_port="example set output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/>
<connect from_op="Filter Example Range" from_port="example set output" to_port="result 1"/>
<portSpacing port="source_input 1" spacing="90"/>
</process>
</process>
