<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="set_macro" compatibility="5.3.013" expanded="true" height="76" name="Set Macro" width="90" x="45" y="30"> <parameter key="macro" value="a"/> <parameter key="value" value="value"/> </operator> <operator activated="true" class="set_macro" compatibility="5.3.013" expanded="true" height="76" name="Set Macro (2)" width="90" x="179" y="30"> <parameter key="macro" value="b"/> <parameter key="value" value="a"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.3.013" expanded="true" height="76" name="Generate Macro" width="90" x="447" y="30"> <list key="function_descriptions"> <parameter key="desiredOutput" value="macro(macro("b"))"/> </list> </operator> <operator activated="true" class="print_to_console" compatibility="5.3.013" expanded="true" height="76" name="Print to Console" width="90" x="581" y="30"> <parameter key="log_value" value="%{desiredOutput}"/> </operator> <connect from_op="Set Macro" from_port="through 1" to_op="Set Macro (2)" to_port="through 1"/> <connect from_op="Set Macro (2)" from_port="through 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Print to Console" to_port="through 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
