I have Rapid Analytics installed on a 64-bit Windows Server. I'm using the 64-bit version of Java to launch the application. It randomly crashes when a process is started. The crash log is shown below:
Any help would be greatly appreciated.
Nick
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000022667c43, pid=3508, tid=2020
# JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.45-b08 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ddshdw24.dll+0xc7c43]
# Core dump written. Default location: [thread 2268 also had an error]
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000019914000): JavaThread "QuartzScheduler_Worker-7" [_thread_in_native, id=2020, stack(0x000000001d4a0000,0x000000001d5a0000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x000000000efcb000
<snip> </snip>
VM Arguments:
jvm_args: -Dprogram.name=run.bat -Xms2048M -Xmx2048M -XX:MaxPermSize=256M -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Dorg.jboss.resolver.warning=true -Djava.endorsed.dirs=C:\RapidAnalytics\lib\endorsed
java_command: org.jboss.Main -b 0.0.0.0
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=C:\Program Files\Java\jre7
CLASSPATH=C:\PROGRA~1\IBM\SQLLIB\java\db2java.zip;C:\PROGRA~1\IBM\SQLLIB\java\db2jcc.jar;C:\PROGRA~1\IBM\SQLLIB\java\sqlj.zip;C:\PROGRA~1\IBM\SQLLIB\java\db2jcc_license_cu.jar;C:\PROGRA~1\IBM\SQLLIB\bin;C:\PROGRA~1\IBM\SQLLIB\java\common.jar;.;.
PATH=C:\Program Files\IBM\SQLLIB\BIN;C:\Program Files\IBM\SQLLIB\FUNCTION;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\DataDirect\Shadow\ODBC73\Drivers
USERNAME=nick.dickinson
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 47 Stepping 2, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows NT 6.1 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (1 cores per cpu, 1 threads per core) family 6 model 47 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, aes, tsc, tscinvbit
Memory: 4k page, physical 8273464k(917720k free), swap 16545068k(11806916k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (24.45-b08) for windows-amd64 JRE (1.7.0_45-b18), built on Oct 8 2013 05:47:22 by "java_re" with unknown MS VC++:1600
