Sentiment Analysis: Error Message
User: "pete041"
New Altair Community Member
Updated by Jocelyn
How can I address the following error message in a sentiment model (WARNING: Kernel Model: The given example set does not contain a regular attribute with name 'messag'. This might cause problems for some models depending on this particular attribute.). I replicated a sentiment model from a YouTube video (http://www.youtube.com/watch?v=4EWXf3_0ta4) where the same error message occurs. So I was wondering whether I can disregard the error message, given that others, maybe more experienced users, get the same result or if there is a fix.
Thanks for any suggestions.
Peter
1 - 1 of 11
    User: "MariusHelf"
    Hi Peter,
    can you please post your process setup and the structure of your input data?
    Best regards,
    Marius
