Have you solve this?
I met the same problem with you.
Hmmm... try the Hive JDBC connector to connect to Apache Impala. It doesn't support autocommit either, but it overrides the required methods to make itself compatible with the specifications, which Impala doesn't.
https://impala.apache.org/docs/build/html/topics/impala_jdbc.html
Hope it helps,
Sorry, I don't understand you. Maybe I didn't describe the problem clearly.
I added all dependencies needed in the configuration of driver and want to connect the Impala in RapidMiner. But it shows "Enabling Autocommit Is Not Supported".
It was "org.apache.hive.jdbc.HiveDriver" that I used.
C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\hadoop-common-2.6.0-cdh5.9.0.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\hive-common-1.1.0-cdh5.9.0.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\hive-jdbc-1.1.0-cdh5.9.0.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\hive-metastore-1.1.0-cdh5.9.0.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\hive-service-1.1.0-cdh5.9.0.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\httpclient-4.2.5.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\httpcore-4.2.5.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\libthrift-0.9.0.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\libfb303-0.9.0.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\log4j-1.2.17.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\slf4j-api-1.7.25.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\slf4j-log4j12-1.7.21.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\commons-logging-1.2.jar,C:\Users\liyuhui\lyh\software\rapidminer-8.2.0\RapidMiner Studio\lib\jdbc\guava-18.0.jar
Then I used the same dependencies and writed the code to connect the Impala, it was ok.
So I thought it's something about RM configuration or... I don't know. Can you help me?
@rajabrata is using the Radoop product not an option for you?
I know Radoop can connect hive and Impala database,but what's the reason of this error?
Since you provide the Hive type in the connection configuration dialog, doesn't it mean that it will be ok if I use this way to connect?
I just want to know why it doesn't work.
Thanks a lot.
