We recently upgraded the JRE SE (from version 1.6 to version 1.7.0_45) on our RapidAnalytics servers, and since then we have started having a very odd problem with the Get Page and Get Pages operators. RapidAnalytics version 1.3.013 is running on a Windows Server 2008R2. This time we actually installed the JRE using the "Server JRE" tar file, instead of using the installation program, but I am not sure if this has anything to do with this or not.
On line 89 of the HttpURLConnectionProvider class, the call CookieHandler.getDefault() is returning a null, which then makes the operator fail a couple of lines after this. But interestingly enough, if we restart the service everything works fine for a while (the call returns a cookie manager), but a couple of executions later the problem happens again.
Has anybody experienced a similar problem? Any idea of what else we can look into?
This is an example process with which I am able to reproduce the problem:
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="web:get_webpage" compatibility="5.3.001" expanded="true" height="60" name="Get Page" width="90" x="246" y="75">
<parameter key="url" value="http://elmundo.es"/>
<list key="query_parameters"/>
<list key="request_properties"/>
<connect from_op="Get Page" from_port="output" to_port="result 1"/>
</process>
</process>
These are the top lines of the stack trace:
SEVERE: Process failed: java.lang.NullPointerException
at com.rapidminer.operator.io.web.HttpURLConnectionProvider.getConnectionInstance(HttpURLConnectionProvider.java:106)
at com.rapidminer.operator.io.web.GetWebpageOperator.read(GetWebpageOperator.java:136)
at com.rapidminer.operator.io.web.GetWebpageOperator.read(GetWebpageOperator.java:61)
at com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:126)
at com.rapidminer.operator.Operator.execute(Operator.java:867)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:375)
Thanks!
