<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="open_file" compatibility="5.3.013" expanded="true" height="60" name="Open File" width="90" x="45" y="30"> <parameter key="filename" value="C:\Users\xyz\Test.txt"/> </operator> <operator activated="true" class="execute_script" compatibility="5.3.013" expanded="true" height="76" name="Execute Script" width="90" x="179" y="30"> <parameter key="script" value="import javax.swing.JOptionPane; import com.rapidminer.operator.nio.file.SimpleFileObject; import com.rapidminer.operator.nio.file.RepositoryBlobObject SimpleFileObject fileObject = input[0]; // fileObject.getFile() returns the File which can be used to read it System.out.println(fileObject.getFile()); // for Blobs use this: //RepositoryBlobObject blob = input[0]; return fileObject;"/> </operator> <connect from_op="Open File" from_port="file" to_op="Execute Script" to_port="input 1"/> <connect from_op="Execute Script" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
