Hi David,
a long time after your post I have come to the same problem. It can be remediated with looping and using Get Page inside Handle Exception:
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="82" name="Execute Python" width="90" x="45" y="34"> <parameter key="script" value="import pandas # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) def rm_main(): data2 = pandas.DataFrame({'link':['https://www.presseportal.de/blaulicht/pm/70116/3951184','https://www.nonexisting.ar', 'https://www.tu-dortmund.de/uni/de/Einstieg/aktuelles/meldungen/2018-01/18-01-31-Do-camp-ing/index.html']}) # connect 2 output ports to see the results return data2"/> </operator> <operator activated="true" class="extract_macro" compatibility="8.2.000" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="34"> <parameter key="macro" value="number_examples"/> <list key="additional_macros"/> </operator> <operator activated="true" class="concurrency:loop" compatibility="8.2.000" expanded="true" height="82" name="Loop" width="90" x="447" y="34"> <parameter key="number_of_iterations" value="%{number_examples}"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="8.2.000" expanded="true" height="82" name="Filter Example Range" width="90" x="112" y="34"> <parameter key="first_example" value="%{iteration}"/> <parameter key="last_example" value="%{iteration}"/> </operator> <operator activated="true" class="extract_macro" compatibility="8.2.000" expanded="true" height="68" name="Extract Macro (2)" width="90" x="246" y="34"> <parameter key="macro" value="link"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="link"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="handle_exception" compatibility="8.2.000" expanded="true" height="82" name="Handle Exception" width="90" x="514" y="34"> <process expanded="true"> <operator activated="true" class="web:get_webpage" compatibility="7.3.000" expanded="true" height="68" name="Get Page" width="90" x="112" y="34"> <parameter key="url" value="%{link}"/> <list key="query_parameters"/> <list key="request_properties"/> </operator> <connect from_op="Get Page" from_port="output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <process expanded="true"> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Handle Exception" from_port="out 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="715" y="34"> <parameter key="create_word_vector" value="false"/> <parameter key="keep_text" value="true"/> <process expanded="true"> <operator activated="true" class="web:extract_html_text_content" compatibility="7.3.000" expanded="true" height="68" name="Extract Content" width="90" x="380" y="34"/> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Execute Python" from_port="output 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Strangely enough the Loop Examples operator seems to be broken, therefore I emulated it with the normal Loop operator.
It would be nice if the Get Pages operator could ignore not found responses!
Sebastian
