I am running a cfd simulation of oil lines to determine pressure drops with HyperWorks CFD 2021.1. Having a non-planar fluid inlet surface (fluid enters along a cylindrical surface, there is a valve from which oil enters along the entire inner side area of this cylinder) how do I enter the boundary condition that has a volumetric (or mass) flow rate? I filled the hole and used the volumetric flow entering on the outer surface of the filled hole (i.e., the fluid enters the domain from the circular surface as if from a pipe), is this correct? Is there another solution?
I have another doubt about units, is the viscosity when I create a material the dynamic viscosity (in Pas=kg/ms) or the kinematic viscosity (m^2/s)? (I used for the other input data: distance in m, density in kg/m^3, specific heat in J/kgK and conductivity in W/mK).
I also have the problem of inflow at the outflow boundary, is it correct to extend the volume to have the outlet farther away (to allow the flow to fully develop) and have a reduction in area in the last part of the extended volume to accelerate the flow? Is there any other solution?
I have also the problem of outflow at the inflow boundary, and the value remain constant for the whole simulation, how can I solve also this problem?
Thank you very much in advance
