Marco Boeck wrote:Hi,are you using MacOS?Regards,Marco
Marco Boeck wrote:Hi,can you please post the contents of the rm.log file (user/.RapidMiner5/rm.log) after you restarted RapidMiner and tried to open an Import wizard via "File" -> "Import Data" -> "Import Excel Sheet..."?Regards,Marco
Sep 17, 2013 3:59:36 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>INFO: Default version of expression parser registered successfullySep 17, 2013 3:59:38 PM com.rapidminer.parameter.ParameterTypePassword decryptPasswordWARNING: Password in XML file looks like unencrypted plain text.Sep 17, 2013 3:59:38 PM com.rapidminer.tools.OperatorService initINFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403Sep 17, 2013 3:59:39 PM com.rapidminer.tools.jdbc.JDBCProperties <init>WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)Sep 17, 2013 3:59:39 PM com.rapidminer.tools.jdbc.JDBCProperties registerDriversINFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.Sep 17, 2013 3:59:48 PM com.rapidminer.gui.ApplicationPerspectives loadAllCONFIG: Loading perspectives.Sep 17, 2013 3:59:48 PM com.rapid_i.deployment.update.client.UpdateManager$3 runINFO: Checking for updates.Sep 17, 2013 4:00:04 PM com.rapidminer.gui.tools.WelcomeScreen$2 runINFO: Cannot download news: java.net.ConnectException: Connection timed out: connectjava.net.ConnectException: Connection timed out: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at sun.net.NetworkClient.doConnect(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.<init>(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source) at java.net.HttpURLConnection.getResponseCode(Unknown Source) at javax.swing.JEditorPane.getStream(Unknown Source) at javax.swing.JEditorPane.setPage(Unknown Source) at com.rapidminer.gui.tools.WelcomeScreen$2.run(WelcomeScreen.java:259)Sep 17, 2013 4:00:07 PM com.rapidminer.gui.OperatorDocLoader parseDocumentForOperatorWARNING: Could not open http://rapid-i.com/wiki/index.php?title=Process: connect timed outSep 17, 2013 4:00:09 PM com.rapid_i.deployment.update.client.UpdateManager$3 runWARNING: Error checking for updates: javax.xml.ws.WebServiceException: Failed to access the WSDL at: http://marketplace.rapid-i.com:80/UpdateServer/UpdateServiceService?wsdl. It failed with: Connection timed out: connect.javax.xml.ws.WebServiceException: Failed to access the WSDL at: http://marketplace.rapid-i.com:80/UpdateServer/UpdateServiceService?wsdl. It failed with: Connection timed out: connect. at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(Unknown Source) at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(Unknown Source) at com.sun.xml.internal.ws.client.WSServiceDelegate.parseWSDL(Unknown Source) at com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(Unknown Source) at com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(Unknown Source) at com.sun.xml.internal.ws.spi.ProviderImpl.createServiceDelegate(Unknown Source) at javax.xml.ws.Service.<init>(Unknown Source) at com.rapidminer.deployment.client.wsimport.UpdateServiceService.<init>(UpdateServiceService.java:42) at com.rapid_i.deployment.update.client.UpdateManager.getService(UpdateManager.java:567) at com.rapid_i.deployment.update.client.UpdateManager$3.run(UpdateManager.java:870) at com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:200) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source)Caused by: java.net.ConnectException: Connection timed out: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at sun.net.NetworkClient.doConnect(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.<init>(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source) at java.net.URL.openStream(Unknown Source) at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(Unknown Source) at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(Unknown Source) ... 13 moreSep 17, 2013 4:00:50 PM com.rapidminer.gui.RapidMinerGUI$ShutdownHook runINFO: Running shutdown sequence.Sep 17, 2013 4:00:50 PM com.rapidminer.gui.ApplicationPerspectives saveAllCONFIG: Saving perspectives.Sep 17, 2013 4:00:50 PM com.rapidminer.tools.usagestats.UsageStatistics saveCONFIG: Saving operator usage.
C:\Users\doe-morrisonc\rapidminer\scripts>RapidMinerGUI.batRAPIDMINER_HOME is not set. Trying the directory 'C:\Users\doe-morrisonc\rapidminer\scripts\..'...Using global jre found on path: javaStarting RapidMiner from 'C:\Users\doe-morrisonc\rapidminer\scripts\..' using classes from 'C:\Users\doe-morrisonc\rapidminer\scripts\..\lib\rapidminer.jar'...Creating file "C:\Users\doe-morrisonc\AppData\Roaming\check_rm_java_version"Java Version: 1.6.0_11Removing file "C:\Users\doe-morrisonc\AppData\Roaming\check_rm_java_version"Starting in multicore mode with CMS garbage collector...18-Sep-2013 09:57:52 com.rapid_i.Launcher ensureRapidMinerHomeSetINFO: rapidminer.home is 'C:\Users\doe-morrisonc\rapidminer\scripts\..'.18-Sep-2013 09:57:57 com.rapid_i.Launcher mainINFO: Launching RapidMiner, platform ANY18-Sep-2013 09:58:00 com.rapidminer.tools.ParameterService initINFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.18-Sep-2013 09:58:00 com.rapidminer.tools.I18N <clinit>INFO: Set locale to en.18-Sep-2013 09:58:00 com.rapid_i.Launcher ensureRapidMinerHomeSetINFO: rapidminer.home is 'C:\Users\doe-morrisonc\rapidminer\scripts\..'.18-Sep-2013 09:58:01 com.rapidminer.tools.plugin.Plugin registerPluginsINFO: Register plugin: VISUALIZATIONS18-Sep-2013 09:58:01 com.rapidminer.tools.plugin.Plugin registerPluginsINFO: Register plugin: R Extension18-Sep-2013 09:58:01 com.rapidminer.tools.plugin.Plugin registerPluginsINFO: Register plugin: Text Processing18-Sep-2013 09:58:01 com.rapidminer.tools.plugin.Plugin registerPluginsINFO: Register plugin: Web Mining18-Sep-2013 09:58:02 com.rapidminer.PluginInitR initPluginINFO: Trying to load R Library...18-Sep-2013 09:58:04 com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>INFO: Default version of expression parser registered successfully18-Sep-2013 09:58:06 com.rapidminer.parameter.ParameterTypePassword decryptPasswordWARNING: Password in XML file looks like unencrypted plain text.18-Sep-2013 09:58:06 com.rapidminer.tools.OperatorService initINFO: Number of registered operator classes: 514; number of registered operatordescriptions: 532; number of replacements: 43718-Sep-2013 09:58:07 com.rapidminer.tools.jdbc.JDBCProperties <init>WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)18-Sep-2013 09:58:07 com.rapidminer.tools.jdbc.JDBCProperties registerDriversINFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver isnot installed.[Fatal Error] :1:1: Premature end of file.18-Sep-2013 09:58:13 org.rosuda.JRI.Rengine <clinit>INFO: Creating Connection to R...18-Sep-2013 09:58:13 org.rosuda.JRI.Rengine isJriLoadedWARNING: Access on uninitialized Rengine!18-Sep-2013 09:58:13 org.rosuda.JRI.Rengine isJriLoadedINFO: Engine ID: class org.rosuda.JRI.Rengine ClassLoader:PluginClassLoader ([file:/C:/Users/doe-morrisonc/rapidminer/scripts/../lib/plugins/rmx_r-ANY-5.3.0.jar])18-Sep-2013 09:58:16 com.rapid_i.deployment.update.client.UpdateManager$3 runINFO: Checking for updates.18-Sep-2013 09:58:30 com.rapidminer.gui.tools.WelcomeScreen$2 runINFO: Cannot download news: java.net.ConnectException: Connection timed out: connectjava.net.ConnectException: Connection timed out: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at sun.net.NetworkClient.doConnect(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.<init>(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(UnknownSource) at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source) at java.net.HttpURLConnection.getResponseCode(Unknown Source) at javax.swing.JEditorPane.getStream(Unknown Source) at javax.swing.JEditorPane.setPage(Unknown Source) at com.rapidminer.gui.tools.WelcomeScreen$2.run(WelcomeScreen.java:259)Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: cannot add to layout: constraint must be a string at java.awt.CardLayout.addLayoutComponent(Unknown Source) at java.awt.Container.addImpl(Unknown Source) at java.awt.Container.add(Unknown Source) at com.rapidminer.operator.nio.LoadingContentPane.<init>(LoadingContentPane.java:49) at com.rapidminer.operator.nio.CSVSyntaxConfigurationWizardStep.makePanel(CSVSyntaxConfigurationWizardStep.java:279) at com.rapidminer.operator.nio.CSVSyntaxConfigurationWizardStep.<init>(CSVSyntaxConfigurationWizardStep.java:129) at com.rapidminer.operator.nio.CSVImportWizard.<init>(CSVImportWizard.java:75) at com.rapidminer.operator.nio.CSVImportWizard.<init>(CSVImportWizard.java:48) at com.rapidminer.gui.MainFrame$1.actionPerformed(MainFrame.java:322) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.AbstractButton.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(UnknownSource) at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)18-Sep-2013 09:58:32 com.rapidminer.gui.OperatorDocLoader parseDocumentForOperatorWARNING: Could not open http://rapid-i.com/wiki/index.php?title=Process: connect timed out18-Sep-2013 09:58:39 com.rapid_i.deployment.update.client.UpdateManager$3 runWARNING: Error checking for updates: javax.xml.ws.WebServiceException: Failed to access the WSDL at: http://marketplace.rapid-i.com:80/UpdateServer/UpdateServiceService?wsdl. It failed with: Connection timed out: connect.javax.xml.ws.WebServiceException: Failed to access the WSDL at: http://marketplace.rapid-i.com:80/UpdateServer/UpdateServiceService?wsdl. It failed with: Connection timed out: connect. at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(Unknown Source) at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(Unknown Source) at com.sun.xml.internal.ws.client.WSServiceDelegate.parseWSDL(Unknown Source) at com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(Unknown Source) at com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(Unknown Source) at com.sun.xml.internal.ws.spi.ProviderImpl.createServiceDelegate(Unknown Source) at javax.xml.ws.Service.<init>(Unknown Source) at com.rapidminer.deployment.client.wsimport.UpdateServiceService.<init>(UpdateServiceService.java:42) at com.rapid_i.deployment.update.client.UpdateManager.getService(UpdateManager.java:567) at com.rapid_i.deployment.update.client.UpdateManager$3.run(UpdateManager.java:870) at com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:200) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source)Caused by: java.net.ConnectException: Connection timed out: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at sun.net.NetworkClient.doConnect(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.openServer(Unknown Source) at sun.net.www.http.HttpClient.<init>(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.http.HttpClient.New(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(UnknownSource) at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source) at java.net.URL.openStream(Unknown Source) at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(Unknown Source) at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(Unknown Source) ... 13 moreException in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: cannot add to layout: constraint must be a string at java.awt.CardLayout.addLayoutComponent(Unknown Source) at java.awt.Container.addImpl(Unknown Source) at java.awt.Container.add(Unknown Source) at com.rapidminer.operator.nio.LoadingContentPane.<init>(LoadingContentPane.java:49) at com.rapidminer.operator.nio.AnnotationDeclarationWizardStep.<init>(AnnotationDeclarationWizardStep.java:55) at com.rapidminer.operator.nio.AbstractDataImportWizard.addCommonSteps(AbstractDataImportWizard.java:60) at com.rapidminer.operator.nio.ExcelImportWizard.<init>(ExcelImportWizard.java:72) at com.rapidminer.operator.nio.ExcelImportWizard.<init>(ExcelImportWizard.java:48) at com.rapidminer.gui.MainFrame$2.actionPerformed(MainFrame.java:338) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.AbstractButton.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(UnknownSource) at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: cannot add to layout: constraint must be a string at java.awt.CardLayout.addLayoutComponent(Unknown Source) at java.awt.Container.addImpl(Unknown Source) at java.awt.Container.add(Unknown Source) at com.rapidminer.operator.nio.LoadingContentPane.<init>(LoadingContentPane.java:49) at com.rapidminer.operator.nio.MetaDataDeclarationWizardStep.<init>(MetaDataDeclarationWizardStep.java:258) at com.rapidminer.operator.nio.xml.XMLImportWizard.<init>(XMLImportWizard.java:81) at com.rapidminer.operator.nio.xml.XMLImportWizard.<init>(XMLImportWizard.java:51) at com.rapidminer.gui.MainFrame$3.actionPerformed(MainFrame.java:354) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.AbstractButton.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(UnknownSource) at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
C:\Users\doe-morrisonc\Desktop>java -versionjava version "1.6.0_11"Java(TM) SE Runtime Environment (build 1.6.0_11-b03)Java HotSpot(TM) Client VM (build 11.0-b16, mixed mode, sharing)
In order to use RapidMiner you need a Java Runtime Environment (JRE) version 7
"If you download Java 7, you will not be able to run Java content in Chrome and will need to use a 64-bit browser (such as Safari or Firefox) to run Java content within a browser. Additionally, installing Java 7 will disable the ability to use Apple Java 6 on your system".
java version "1.6.0_65"Java(TM) SE Runtime Environment (build 1.6.0_65-b14-462-11M4609)Java HotSpot(TM) 64-Bit Server VM (build 20.65-b04-462, mixed mode)
paulalford wrote:Hi,I have encountered the same problem as colmoni, but the difference is that I'm running Mac OSX. When starting the Java 7 download I get the following message:Is there a workaround for Mac users?My current Java version is: java version "1.6.0_65"Java(TM) SE Runtime Environment (build 1.6.0_65-b14-462-11M4609)Java HotSpot(TM) 64-Bit Server VM (build 20.65-b04-462, mixed mode) Thanks in advance.
